Scholtes TI 04 66 not heating
Hot Plates not heating
Stove hot plates
sounds like a bad connection have the teck look for an open ground.
Jan 08, 2015 | In Microwave Ovens
One of the stove plates on the mini oven do not heat up
BEWARE : STOP USING IT RIGHT NOW AND CONTACT AUTHORIZED SERVICE CENTER AND DO NOT TRY ANYTHING WITH THIS MACHINE YOURSELF. IF YOU CONTINUE USING IT, IT MAYBE HAZARDOUS AS IT'S AN ELECTRIC EQUIPMENT.
Mar 29, 2014 | Kitchen Appliances - Others
Scholtes oven
try moving the unit to a different power outlet, it might not be getting enough power = AMPS .. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 13, 2013 | Microwave Ovens
What is a Laboratory Hot Plate?
Wikipedia says: A hot plate is a portable self-contained tabletop small appliance that features one, two or more gas burners or electric heating elements. A hot plate can be used as a stand alone appliance, but is often used as a substitute for one of the burners from an oven range or the cook top of a stove. Hot plates are often used for food preparation, generally in locations where a full kitchen stove would not be convenient or practical, as hot plates are easily moved from one location to another.
May 01, 2013 | Science & Laboratory
What are hot plates used for?
hot plates are used to heat glassware or its content. Many hot plates also have magnetic stirrers
Jan 13, 2013 | Science & Laboratory
Hot plates not heating up
Hi kennycrocket,
You might be looking at dead plates or faulty regulators. I'd suggest lifting the cooktop of, and turning it over. Then very carefully, while still on at the main, testing at the power points with a multimeter.
First test incoming power to the regulators (The devices found under the knobs), then testing power to the plates. If power gets to the regulators, but not to the plates - The faulty part is the regulators. If however power goes to the regulator as well as the plates, then the plates are faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 | Belling 23 in. SHU53 Electric Cooktop
My Conair Proshine Straightner won't warm up, although the light is on. How do I fix this? ... hot plates not heating and the light says its warming up but the hot plates won't heat up
Most heated hair appliances are protected by a thermistor that will fail if overheated. These are small, about 1/2" long, cylindrical in shape with a pointy end and a wire coming from each end. When they go bad, they do not conduct electricity (zero ohms on a meter). There is a three digit number on the side that is the shutoff temperature. You can get these at Radio Shack.
Don't bypass this safety device.
Jan 07, 2011 | Conair Professional Ceramic Hair...
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
jasbo
jasbo
