Question about Acer TravelMate 2300 Notebook
Start up i have error. ''error set up abort'' and ''driver signing policy disabler'' come up on the screen when i'm trying to install xp professional
We have a KM bizhub 250, and we upgraded our server to a SBS 2008 Server. Now our scanning is not working. What could be the problem?
If this server is also a domain controler that is usually caused by the following setting:
Microsoft Network Server: Digitally Sign Communications (Always), The default setting for domain controllers is enabled, for others is not configured or disabled. This usually causes problems when acessing the share from devices are not cable of Digitally Sign Communications, like some multifunctionals/scanners or linux machines. This does not happen on all machines since some are capable of Digitally Sign Communications. Usually older machines have this issue.
So, try to disable this setting on the server, on the Domain controller security policy and Default Domain Policy.
Administrative Tools
Local Policies
Security options
Microsoft Network Server: Digitally signed communication (always) -> should be changed to DISABLE
Execute Gpupdate /force or reboot the server to apply the policy change
You will not be able to change this setting trough gpedit , local computer policy since it is overrided by the Domain security policy.
On server 2008 one way to get there is the following:
Server Manager
Features
Group Policy Manager
Forest: ...
Computer configuration
Policies
Windows Settings
Security Settings
Local Policies
Security Options
- Define This Policy
- Disabled
Execute Gpupdate /force or reboot to apply policy
Trough gpedit you will be able to see the option but not change it, so I suggest that after the change you cannot scan to the folder check trough gpedit if it is disabled.
If it is not disabled, disable it at the top of the hierarchy. Something may be overriding the setting.
If it still does not work try the following, togheter with the previous setting
Domain member: Digitally encrypt or sign secure channel data (always) -> disabled
Dont forget to execute Gpupdate /force or reboot to apply policy each time you change something.
Also
are you scanning to the server using \\server_ip_address\shared_folder or \\server_name\shared_folder?
Just wondering about name resolution.
Is the domain field configured in the machine? if not you might have to specify the user for authentication like for example: user@domain.local
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
Tip
Disable Automatic Reboot after Windows Update
Have you seen the message
"Automatic Updates
Updating your computer is almost complete. You must restart your computer for the updates to take effect.
Do you want to restart your computer now?"
Automatic Windows updates are very good for computer security. However, when these Windows updates are downloaded and installed on your computer, if the updates require a reboot of your computer, Windows keeps prompting you to reboot your computer.
Now, Windows XP Pro users can disable automatic reboot of the computer after a Windows Update. In order to do that, follow these steps
Disable Automatic Reboot after Windows Update for Windows XP Pro usersWith this setting you will be able to specify that after a scheduled Windows update, Automatic updates will wait for the computer to be restarted by any user who is logged on, instead of causing the computer to restart automatically. If this setting is not enabled or not configured, your computer will prompt you every 5 minutes to restart the computer to complete the installation.
1. Press <Windows Key> + R which will launch the Run command. Type gpedit.msc and press Enter
2. Group Policy Editor will now be launched
3. On the left hand pane, under Local Computer Policy, click on the (+) sign next to Computer Configuration
4. Click on the (+) sign next to Administrative Templates. Then click on (+) next to Windows Components and then click on Windows Update
5. Double click on No auto-restart for scheduled Automatic Updates installations. A settings window will now open. In there, select Enabled and then press OK
6. Close the Group Policy Editor
Disable Automatic Reboot after Windows Update for Windows XP Home usersThe settings are a bit different for Windows XP Home users because there is no group policy configuration for Windows XP Home.
1. Press <Windows Key> + R and type in regedit. Press Enter
2. Navigate to
HKEY_LOCAL_MACHINE SoftwarePolicies MicrosoftWindows WindowsUpdateAU
3. Change the "NoAutoRebootWithLoggedOnUsers" DWord value to 1 to Disallow auto reboot.
4. Press OK
if this tip really help u pls vote ,...........shailendra
on Oct 03, 2010 | Computers & Internet
Tip
Steps to improve the shutdown times.
Start Registry Editor and navigate to the following key:
[HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management] Set ClearPageFileAtShutdown value to 0
Or, using Group Policy Editor [for Windows XP Professional]
Click Start, Run and type Secpol.msc
Click Local Policies | Security Options
In the right-pane, set Shutdown: Clear virtual memory pagefile to Disabled
However, this setting is not the only cause for slow shutdowns. Non-responsive programs and Services also contribute to slow shutdowns. If the problem is seen recently after installing a third-party driver or software, try a System Restore rollback to see if that resolves the slow shutdown problem.
on Mar 09, 2010 | Computers & Internet
Blue screen. 0x0000008e (0xc0000005,0x80409A88,0xf789e360,0x00000000.
This error occurs due to the following reasons: Faulty RAM, registry errors, incompatible drivers, hardware failures, faulty BIOS configuration, Viruses.
Follow the steps below to avoid the BSOD error message occurs again.
Check whether the RAM installed in your computer complies with the motherboard specs. Replace the RAM if needed. You can also check the systems with a friend's RAM to know whether the error message is due to RAM.
Use a free registry cleaner/fixer software available to clean/repair your windows registry. (Ccleaner is good at this)
Do not install incompatible device drivers. Install only Microsoft Signed drivers. Update your existing driver software from the corresponding device manufacturer's website.
If you have installed/changed new hardware, check whether it is supported by your system. Also check whether it is installed properly. If needed test the systems without the faulty hardware. Check whether you've installed correct/signed driver software for that particular hardware.
If you have reconfigured your system BIOS, set it to default/optimal/recommended settings and test the system. Disable features like BIOS caching.
Use an original and up to date antivirus system like Norton, McAfee or Kaspersky and run a full systems scan.
Keep your windows updated with current patches and fixes to protect the systems from unwanted troubles.
All the best.
Mar 06, 2010 | Microsoft Windows XP Professional for PC
Task manager is disabled by administrator
So your task mananger isn't working, this may be a Virus, or simply some programs error? Anyway, If you have Windows XP Pro, there's a nifty user interface to directly edit the setting you want to repair. Click Start, then click Run and type in gpedit.msc: And press OK. This runs the Group Policy Editor. Once in the Group Policy Editor, expand in turn: User Configuration Administrative Templates System Ctrl+Alt+Del Options You should see the Group Policy Window, Double click on Remove Task Manager to change its setting: It should be enough to click on Not Configured and then OK and Task Manager is available once again. If you don't have Windows XP Pro, then you'll need to edit the registry manually. Click Start, then click Run, type in regedit, and click on OK. Expand these registry keys in turn:
HKEY_CURRENT_USER \Software \Microsoft \Windows \CurrentVersion \Policies \System You should see the key DisableTaskMgr in the right hand pane. Right Click on the DisableTaskMgr item: Click on Delete, confirm that you want to delete, and Task Manager should be available once again. One thing to note is that it's quite possible that if you're in an environment managed by a centralized policy, these settings may have no effect. Your IT administrator may set things up so as to disable Task Manager, and other things as well at the domain level. You'll need to ask them if this is the case.
Feb 17, 2010 | Microsoft Windows XP Professional
Whenever i download and install any torrent file on my pc, i get a message to restart. when i restart the system, no icons will be displayed on the screen and not even the task manager gets operated. i get...
For task manager
1. Verity that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
"Task Manager".
1.1 "Local Group Policy"
a. Go to "Start" -> "Run" -> Write "Gpedit.msc" and press on "Enter" button.
b. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
c. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".If so set to other and viceversa
d. Close "Gpedit.msc" MMC.
e. Go to "Start" -> "Run" -> Write "gpupdate /force" and press on "Enter" button.
Note: If you are using Windows 2000, please follow KB q227302 instead stage "e".
Using SECEDIT to Force a Group Policy Refresh Immediately
http://support.microsoft.com/kb/q227302/
1.2 "Domain Group Policy"
a. Contact you local IT support team.
2. Verity correct registry settings::
a. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
Warning: Modifying your registry can cause serious problems that may require you to reinstall your operating system.
Always backup your files before doing this registry hack.
b. Navigate to the following registry keys and verity that following settings set to default:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
c. Reboot the computer.
For no icons
go to run just type " explorer " and that should be it
Jun 06, 2009 | Microsoft Windows XP Professional
Disabled task manager
"Task Manager".
May 23, 2009 | Microsoft Windows XP Professional SP2
Taskmanager disabled by your administrator
Click on start then run
Type gpedit.msc then ok
Click + on administrative templates
Click + on system
Click on CTRL ALT DEL options
over to the right double click on remove task manager
Click on disabled then apply then ok
You will now have back taskmanager
This is normaly caused by malware you should if you havent already run an anti malware scan.
Malware Bytes is an excelent example of a scanner and is located here: www.malwarebytes.org get the free trial version its great.
May 07, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
