Toshiba LCD colour tv 27WL56P can't get TV since switchover
SOURCE: Toshiba LCD Colour TV (Model 15VL63B)
the invertor board faulty
Martin
Posted on Jan 28, 2008
SOURCE: Samsung LE40R87BD LCD TV
Did you find a solution , got exact same problem
Posted on Nov 21, 2010
  • 639 Answers
SOURCE: Toshiba 32AV700A 0" LCD TV
You can download from here :
http://www.mytoshiba.com.au/support/televisions/lcd-tv/av700a/32av700a/download
Hope this help and if helpful RATE please.
Posted on Mar 10, 2011
SOURCE: In just bought new Toshiba
I have problem with tuner the our Tivi Toshiba Regza 32c3500e. When tivi is ON the picture is terible for temporary ( snowy and colours are not good ) and then automatically the picture good without any to do something and vice verca to many time.
I wont to help our tivi problems. Thangking you
Said Joenaidi - Jakarta - Indonesia
Posted on May 20, 2011
  • 184 Answers
SOURCE: Our Toshiba Regza LCD TV
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in solving the problem....
Posted on Aug 06, 2011
How should I switch my Toshiba LCD TV, model no 32AV615DB into digital.
There should be a switchover in you tv settings in your Menu.
Oct 24, 2013 | Toshiba Televison & Video
Poor picture quality on alba LCD TV after recent digital switchover.
Digital TV uses less airspace than analogue TV, so after the digital switchover there'll also be more room for services such as high-speed mobile broadband and high-definition television (HD TV).
Sep 16, 2012 | Televison & Video
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
I need a toshiba LCD colour TV user manual model no 40LV800A
try either the Toshiba site or Google the model number with 'manual"
Jun 11, 2012 | Toshiba Televison & Video
Red button doesn't show on Philips TV after digital switchover
What is the exact model number to your Philips TV?
Apr 21, 2012 | Televison & Video
I have 2 alba tv/dvd combi's.1 in kitchen & 1 in bedroom.After digi switchover 1 in kitchen is fine after re tuning.The bedroom tv only has a few stations after numerous re tunes.Both work off
The one that does not work: have you tried to unplug it for a while from power and plug it back to see if it will reboot and allow you to program?
Apr 08, 2012 | Televison & Video
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
I have built in Freeview in my Hannspree television. The picture has completely gone, and I have tried retuning, but to no avail. The message is 'database empty', but according to the operator at...
This tv is a flat LCD tv wright?Not a big bulge back CRT tube tv,If this is CRT tv is analoge design tv dosen't have freeview Digital Tuner inside of the tv.If it is a flat LCD tv.Make sure ur setting for retuning not on CALBE SETTING.Make sure ur tv setting are AIR SETTING and have good Digtial antena will get a stronger signal get all the free AIR broadcasting stantoins channels,a good strong Digital antenna design does make big a different.
Aug 04, 2011 | Hannspree (K206-10U1-005) Television
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.
You can then select the SCART connector for the sky box to record programs.
This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
Jan 12, 2009 | Philips DVDR70 DVD Recorder
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
