My toshiba washing machine AW-9760S has a washing cycle of maximum 44minutes. at the end of washing cycle my clothings are not thoroughly clean. In comparism to other washing machines that wash for at least 2hours. what can i do about this?
5 Suggested Answers
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Posted on May 11, 2008
FitzOriginal
  • 842 Answers
SOURCE: Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
Ariston "Margarita 2000 cpu map photo
Posted on Nov 20, 2009
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
My clothes somestimes have a brown stripe on them from the washer, what is the cause of this
Your washer is due for a cleaning. pour 2 cups of vinegar into the empty washer, set it for maximum water, max. heat and longest cycle and start it. This will thoroughly clean the entire inside and solve your problem.
Jul 14, 2009 | Kenmore Elite 45986 Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Hwd1000 washer dryer combo is not moving into the drying cycle
Its time you found out where your filter is to clean out thoroughly
Mar 02, 2009 | Haier HWD1000
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Debrie found on clothes after washing
This is sometimes caused by grease coming from the drum bearing through a failing seal. If this isn't checked and repaired as necessary, the drum bearing will fail pretty soon and then the machine will make a nasty grinding noise and that will be the end of it. I hope you have some other cause in your case! Do make sure the filter is cleaned and then run the machine on a hot cycle with no clothes in it to give it a really good clean.
Hope this helps. D.
Jul 17, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
212 people viewed this question
Top Washing Machines Experts
