Question about Aiwa XR-H330MD Shelf System
XR--H330MD MD/CD STEREO SYSTEM AIWA
THE CASSETTE TAP HOLDER BROCKEN.
IS IT POSSIBLE TO BY A RE PACMENT CASSETTE TAP UNIT, OR A NEW ABOVE SYSTEM
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
ponker
SOURCE: fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Posted on Mar 26, 2009
Suraido
  • 195 Answers
SOURCE: The CD player won't recognize CD's.
Most of those CDs they sell are just a gimmick, nothing can replace a good hand cleaning with a cue-tip done by taking the whole thing apart. Take it to the local technician to get it cleaned properly first and foremost, or do it yourself if you feel safe enough taking all this apart and cleaning a tiny fragile little lens with a cue-tip and windex yourself. If a good hand cleaning like that does not work, then it means the reader head itself is defective and need to be replaced. If this is the case, don't bother. A cheap head will go for around 200$ usually and sometimes more, and at the price you get a new complete system it will be better buying a whole new sound system.
Posted on Jul 07, 2009
  • 133 Answers
SOURCE: where do I get drive belts for a aiwa xr-m10
Try eBay, i've been looking for these on the internet, they sell kits (long and short variety), containing several pairs of different measures (about $7 per kit), and are supposed to fit various brands and models (including aiwa).
...a hint: a belt measure tells you the diameter of the circle formed by that belt
...another hint: old belts are loose, which means they are a bit longer than the new ones, so when you select the new belt from the kit, it should be a bit shorter than the one you removed from the deck (old belt - bigger circle, new belt - smaller circle).
I'm aware that not all aiwa models are the same, the one i was repairing a while ago had a double tape deck, each deck containing two belts, one long and one short, they were a bit tricky to change, but i didn't need to disassemble any of the mechanisms, i just had to remove both decks from the housing for easier access to the belts which required prior removal of the top cover and rear panel. After that it was some 4 to 6 screws and 4 connectors (just about half less in your case, i believe).
I can't tell what your unit looks like on the inside, but in my opinion aiwas are relatively easy to take apart, but then again, i could be wrong...
Hope this helps you get closer to a solution.
regards
3rq8 (Triarcuate)
Posted on Jul 17, 2009
  • 28 Answers
SOURCE: Aiwa Stereo XR EM 50 the cassette deck does not
http://www.yelp.com/biz/audiomaxx-bronx
Posted on Mar 01, 2011
Can you repair/replace the CD drive in an Aiwa XR M00U shelf system? All other functions fine.
Repair; I doubt it, Replace; yes, but the hard part would be finding a replacement unit. You would have to open the case to find out what type of connectors it has and go from there. In the long run you're going to spend more time and effort than it's really worth. That isn't a newer stereo system so consider that you've gotten your moneys worth of life out of it. Best suggestion is to put a new stereo on your Christmas wish list.
Nov 16, 2014 | Aiwa Audio Players & Recorders
What type of cord do i need to connect my subwoofer to the aiwa XR-EM20 stero system i bought a adapter and the red and white plug ins fit in my subwoofer but the the other side that supposed to plug into...
The picture is unclear what size that is but they make adapters for RCA-Stereo-Cable-pair-to-single RCA (Y-adapter) or to smaller 3/16" mono or stereo jacks.
The manual in case you need it. No guidance on operating the optional sub.
http://www.docs.sony.com/release/CXLEM20.pdf
Your unnamed sub's manual should have some advice, huh?
May 17, 2011 | Aiwa XR-EM20 CD Shelf System
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
Feb 05, 2009 | Car Audio & Video
I connected an external MD to Aiwa XR-EM220 but it doesnt work...
If I remember correctly its the button on the front that says AUX, if not then check with the website and find out for sure http://www.us.aiwa.com/default.asp?page=support&browse=yes&cat=7
Feb 29, 2008 | Audio Players & Recorders
Stereo problems
I would have to say that both of these sound as though they are probably beyond economical repair.
With the first unit you mention, either the panel with the switches on needs replacing or the logic (the brain inside) is on it's way out.
On the other system, either the lenses need cleaning or the lasers are on the way out for both MD & CD. You can try cleaning the lenses first, it might help.
What I would very much recommend in the future is to get a system made of seperates. Then, if one source goes down, you're not left with no music while it's being serviced. If you go to Richer Sounds they'll give you a part-exchange allowance for your old hi-fi(s) and if you buy the warranty & never use it they will give you 100% of your money back. Every one's a winner!
Jan 08, 2008 | Audio Players & Recorders
Fixing aiwa stereo
Dec 25, 2007 | Aiwa Audio Players & Recorders
52 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
