Question about Refrigerators
Intergrated prima whirlpool fridgefreezer LPR255 MODEL fridge is not getting cold enough only going to 10 does it need a new stat?
Top of fridge not detting cold enough only 10
22yooper
  • 828 Answers
SOURCE: freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Posted on Jun 09, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 2333 Answers
SOURCE: WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Posted on Nov 27, 2009
  • 207 Answers
SOURCE: Fridgefreezer top fridge section has stopped
see if the back panel inside the refr comes off if it does and u have a fan back there make sure it is working if not make sure its gettin power to it and if it is and not running then replace it and see if this corrects the problem if this fails see if u have a duct going from the freezer to the refr if u do take it apart and see if somethings blocking the airflow or if it has a door thats stuck shut and not letting air go thru
Posted on Mar 01, 2010
Whirlpool tropical fridgefreezer making clicking noise and getting heat from top freezer
Hi, you will need to post this to the FixYa Fridge/freezer forum as this is the washing machine one, sorry ;-0( John C
Oct 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Refrigerator not getting cold enough
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
My ge fridge is not getting cold. there is ice in the two top holes. the freezer is cold fine. i already changed the defrost timer.
First, defrost the unit fully.  If there is ice in the air flow channels, it can't cool enough.  Most cold air comes from the freezer area into the fridge by these channels.  Why did you change the timer?  Did you see if the heater element is continous and properly connected to the harness?
Did you clean out the condenser area?  If dirty or clogged, you won't cool enough.  Do that before anything else.  Is the stat set properly?
If the gas level is low, you won't cool enough to run the fridge portion....and you will get icing.  Check gas level:  Unit off at least an hour.  Start it and note the larger of the two pipes coming out of the compressor.  It should get cold, frost and then either dry out or get droplets of water on it after at least 10-15 minutes.  What happens sooner is unimportant.  If it stays frosted, you'll likely need gas.
Nov 14, 2008 | Refrigerators
Freezer cold but not fridge
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ge profile fridge bottom freezing up
found the problem .the compressor is not putting out enough cold to freeze the coils' only half the coils are freezing in the bottom of the fridge. the fan draws it's cold air from these coils and pulls it up to the top of the fridge where it's dispersed into the top half of the fridge' hence the stat never see's that it's cold enough to shut off the switch . in other words if the coils down below were all working a lot more colder air would be pulled up to the top and the stat would then shut off . Solution is to seek a refund from the service tech and buy a new fridge . it's not worth putting a new compressor into this one although it is only 5 years old hope this helps someone who has the same problem
Mar 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
212 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
