Question about Maytag Dryers
I have maytag mtd09wh. Six weeks old. A red square light, has come on
A red square light has come on six weeks old ,
funkyjacob
  • 76 Answers
SOURCE: No Picture or sound, red standby light blinks six times
Sorry for how long it is but you should be able to find what is wrong in this guide
If you have any questions please dont hesitate to ask
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Dec 03, 2008
SOURCE: Blinking red standby light flashes
blinkig red stand by stay on when powr button hit
Posted on Feb 01, 2009
  • 92 Answers
SOURCE: same problem, vizio 47" LCD TV, six month old
change out the LVDS cable (the cable that go from the control board to the main board) and it should resolve your problem. If your TV is still in warranty, call 1-877-MY-VIZIO and they will set up an in home repair for free.
Posted on Jul 01, 2009
SOURCE: KDF-E60A20 Red Light Flashing 6x
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
Posted on Jul 09, 2009
  • 157 Answers
SOURCE: sony xbr 60 tv has lost red color
SONY IS INVOLVED IN A CLASS ACTION SUITE-problem is a bad light engine-check into this on the web-check your model number to see what they are willing to do.
IT IS A COSTLY REPAIR IF YOU HAVE TO PAY A TECHNICIAN
Posted on Sep 03, 2009
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
There are 2 red light flashing on my 2001 celica when alarm is armed??? is this correct
does it bother you?,does it work correctly??,then what is the problem?
Jul 06, 2015 | 2001 Toyota Celica
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
TV shuts off after on for 5 minutes, Red temp light blinks once every 5 seconds, The power light stays red and blinks and you can hear fan running until unit is unpluged. You can turn it back on but the...
bad connection inside in motherboard. If you are familiar with soldering check for bad connection inside and re-solder that connection . if not find a technician who can help you!!!
Sep 12, 2009 | Televison & Video
Does not turn on.
The Six blinks mean that the thermal fuse needs to be changed.
Jul 07, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Six blinking red lights when trying to turn on.
The power supply board went dead. Have it repair or replaced. No other way around this. Thanks, mike H.
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Dryers Logo
21 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
