Question about Dishwashers
NEFF dishwasher salt chamber solidified - how to solve? It stops adequate filling.
THE SOLIDIFIED SALT CHAMBER stops adequate water filling, and so no washing and rinsing. Can it be dissolved? How to remove the chamber?
SOURCE: Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
Posted on Jan 22, 2008
  • 1462 Answers
SOURCE: salt for DDW1805 Danby
yes it is - salt is used to regenerate the water softener in the dishwasher
Posted on Jul 12, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Posted on Aug 26, 2009
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Feb 17, 2013 | Miele Premier-Plus Built-in Dishwasher
Waterside water softener model MC250 Dear Sir, Salt level did not go down during regeneration. I poured 2 pints of warm water to break solidified tablet salt, I found moist salt, but very little water in...
the salt in use should water softener salt and nothing else
there is water added to the salt crystals up to the overflow hole
during regeneration that salty water (Brime) is drawn into the unit and upon finishing the process that reserve is refilled for the next time
there is little salt actually used during the regeneration process ( around 4 regenerations to a 25 kg bad )
Apr 13, 2017 | Dishwashers
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
Feb 28, 2011 | Neff S5946 Built-In Dishwasher
I have just purchased a new Miele dishwasher. I filled the salt reserve as required but whenever the cleaning cycle finishes it reads Add salt! The salt reserve is already full! Please could you...
Hi Carol
You MUST add water into the softener reserve chamber, normally water first then salt.
Dont worry its a common mistake.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Miele Dishwashers
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Dishes seem to have a powery residue on them after they're clean
Check inlet water quality for hardness. If salt chamber is provided, fill the chamber with salt meant for washing machine.
Use the recommended wash soap.
Check rinse aid and fill if required.
Jul 20, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
White film on glasses. Cannot find solution,
Check water quality. clean the drain filter in the machine. Check spray arm spray jet holes. Clean if clogged.
If you suspect salt chamber try removing all the salt by flushing with water externally. Refill with fresh salt.
Jul 08, 2010 | Servis 23 in. M4306 Free-standing...
I put powder detergent in salt compartment in my dishwasher by mistake. What do I do next?
Just flush it out by pouring plenty of water into the receptacle. You don't have to get every last trace out. Make sure to wear rubber gloves and possibly eye protection as the powder is caustic and so you need to avoid skin and eye splashes.
You could alternatively leave the salt chamber cap off and run the dishwasher empty for a couple of cycles; that will allow the powder to dissolve without any chance of you getting splashes on your skin.
Nov 13, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Low salt light
try stirring the water in the salt container. however, as long as you renew the salt now and again, it doesn't matter
Jun 24, 2008 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
