Question about Hotpoint VBXR1070W
Cold Water Solenoid Problem
The cold water solenoid valve does not shut off when the machine starts to agitiate and the tub overflows onto the floor of the laundry room. I do not thins it is the level sensor because if you wash in hot water the tub does not overflow until you get to the cold water rinse cycle. What confuses me is that the solenoid will open and shut during the spin/rinse cyle. What is the most likely cause for this? Oh somethiong I also for got to metion is the the solenoid will remain open even when you pull the push/pull switch out. How does the solenoid continue to get power when this switch is open?
  • Steve Anderson Jul 09, 2007
    The only reason I think it is not the level switch is that the machine will wash at all three levels on hot. The agitiator wil also start on time on the cold water wash or rinse cyle low, medium or high ,but the water contiues to flow into the tub. I am wandering if it is possible to have a short in the timer which could cause this?
  • 5,911 Answers
The fill switch has a diaphragm that could be damaged and not closing properly. I have personally experienced this problem before. The way water could be getting by the switch (even with no power applied) is simply water pressure in the lines. I don't understand why it would work during the spin and rinse cycles, however. If you say it's not a pressure switch problem (level sensor), then I would invest in a new fill valve. I hope this helps.
Posted on Jul 09, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 10, 2007
    My experience tells me that you more than likely you have a bad fill valve. It's an easier and less expensive fix to try first. Most timers can run $100-$200 to fix. A fill valve is generally $40 or less. Anything is possible...
SOURCE:
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Kenmore front loading washer. I normally leave the front door open when not in use. I came home the other night to water dripping from my dining room ceiling (Washing machine is on second floor...
The water solenoid could be defective. A solenoid is an electrical switch that pulls a shaft out of the water line to let the water flow in. The timer controls this along with water level sensors. That solenoid is a big electric magnet that operates when the power is applied to the electric coil and it snaps the shaft out of the water line allowing water to flow. It also compresses a spring around the shaft and when the power is removed from the coil, the spring snaps the shaft(valve) back into the seat of the water line. If the spring is weak or broken or blocked by debris from hard water, it does not close all the way and allows water to leak. Very similar to a leaky faucet.i expect that the solenoid will have to be replaced.
Jan 11, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore front loader and water keeps on leaking into the tub even though the machine is off.
This is likely due to a foreign object caught in the solenoid valve mechanism - which is usually located at - or very near - the point that the supply water hose attaches. It could also be a faulty seal inside the solenoid valve as well. Either way, changing the solenoid valve will usually solve the problem. Many solenoid valves assemblies control both hot and cold water supply lines, but if yours has separate solenoids - you should determine if it is hot or cold water that is leaking past the seal - and get the appropriate replacement part. Once changed out, the leak should stop.
The washer's water supply should be shut off before the supply hoses whenever not in use. This is especially important if using the cheap rubber hoses instead of the metal mesh type. The hose will eventually fail, and when it does, the water will continue to flow onto the floor until it is shut off by a person.
I hope this helps!
Sep 14, 2010 | Washing Machines
Cold water fills the tub even when machine is not
This is almost definatley the inlet valve faulty.The inlet valve is literally stuck in the open position.You will need to change the inlet valve.I hope this helped you.
Jun 01, 2010 | Washing Machines
Continuously adds water, won't cycle & agitate, spins only when manually move dial.Please Help!
If the water is not overflowing onto the floor, then you have a water siphoning problem. raise and loop the drain hose behind the washer so that it is higher than the water level in the machine.
if the water runs over the top of the tub onto the floor and doesn't shut off until you turn the machine off, then you have a pressure switch problem.
if the only way to shut the water off is to turn it off at the faucet then you have a water valve problem.
May 25, 2010 | Whirlpool Washing Machines
Whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Overflow - Cold water shutoff not working?
Sounds like the cold water valve is faulty. You can try to remove it and clean the inside if it's clogged or replace it completely.
Jun 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
281 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
