Question about Epson Stylus D88 InkJet Photo Printer
MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
THE INK CHARGE AND PAPER FEED LIGHTS ARE FLASHING.
MY PRINTER DID NOT CHARGE THE INKS AFTER I REPLACED A CARTRIDGE , INSTEAD IT ASKED ME TO REPLACE THE INKS AGAIN AND THE LIGHTS BEGAN TO FLASH, PREVENTING ME FROM PRINTING OUT.
  • Epson Master
  • 419 Answers
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
Posted on Feb 17, 2009
Epson D88 will not print, both red lights flash, message remove obstruction switch off and on. No change still 2 redlights flashing
The Lights can flash on an error and also iff the INK levels are down. You must check the ink levels and try to do a reset with printer software reinstalled.
Remvoe pinter from the PC, unistall and then reinstall to see if the printer shows the INK level exactly. If not replace INK cartridges to confirm.
Nov 16, 2010 | Epson Stylus D88 InkJet Photo Printer
I replaced the blue catridge and now both red
If the red lights are flashing simultaneously, it means that there is something blocking the printhead from moving. check if all inks are installed properly and the ink carriage cover is closed tight. If both red lights are flashing alternately,it means that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
Apr 11, 2010 | Epson Stylus C88 InkJet Photo Printer
I have an Epson D88 Inkjet Printer which is a couple of years old. Both the ink and the paper lights or flashing. The manual recommends taking to the dealer but it is not worth it. Any tips on a quick fix?
Could it be you're out of ink and paper simultaneously? But is it even worth buying more ink to find out if this is the cure? If so, I'd try generic ink cartridges to minimize the cost of the experiment. On the other hand, you could probably replace the printer, with new ink cartridges for not much more than the cost of ink for your old printer. They're made to be throwaway, unfortunately.
Nov 18, 2009 | Epson Stylus D88 InkJet Photo Printer
Alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson Stylus Photo 900 InkJet Printer
Epson d88 printer just floods the paper with ink
Sounds a lot like you have an ink pressure issue and at a guess you are using a CIS (Continuous Ink Supply) system.
I would refer back to the documentation that came with your printer and make sure that you are not overpressuring the printhead with the ink reservoirs set too high or some part of the priming process has been missed.
More information about your printers setup would definitely help ID more specific issues that could be causing this.
Mar 24, 2009 | Epson Stylus D88 InkJet Photo Printer
My epson d88 printer has 2 flashing lights, the ink charge and paper feed lights. this is preventing me printing out. this happened after i tried to change my inks. can anybody help?
I just had the same problem. Try opening the top flap on the printer and see if you can click the lid down on the ink cartridge box more firmly (until it clicks) - i had to force the cartridges to the left slightly to do this, although I'm not sure if thats neccessary. Then i pushed the cartidge box back to the right where it was before. The 2 red lights still flashed for me, but when i turned the printer off and on again it worked just fine. I hope this helps.
Jan 23, 2009 | Epson Stylus D88 InkJet Photo Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Epson D88 lights flashing
Jane, contact Epson directly - if you printer is under 12 months they mat replace it
Feb 25, 2008 | Epson Stylus D88 InkJet Photo Printer
Epson Stylus D88 InkJet Photo Printer Logo
664 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
