Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
No problem but what is timer save on wd440
I am not sure what this is is it quick wash or is it for small amount of clothes? Thanks
  • carriersea Jan 23, 2009
    Was not sure but I thought it was either for small load or fast wash type of program Any way thanks
  • Hotpoint Master
  • 3,463 Answers
Quick wash is normally used for clothes that are lightly soiled, and do not require a full wash programme,it has nothing to do with the amount of washing in the m/c.
Time saver cuts down on the actual length of the prog, by approx 1/3, there by saving time, again you would normally use this for washing lightly soiled clothing, it is only available on progs B-D and G
Plz rate my solution.
Thanks.
Posted on Jan 23, 2009
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Sep 06, 2014 | Washing Machines
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
When I have only one item or a very small amount of clothes in washer no matter whether it is set to normal or quick wash, it doesn't spin the clothes dry. I have to try to put it with a bigger load to...
If you just got it I would call the manufacture it comes with a 1 year warranty might be a board or sensor issue there are sensor's that tell how much weight is in there so it knows how fast to spin the drum thats where the power saving features come in.
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wont always drain and clothes are wet, pump has been replaced by repair man still happens
MAKE SURE YOUR OUTLET HOSE GOING TO THE DRAIN IS NOT BENT THIS CAN CAUSE THE WATER NOT TO EXIT PROPERLY, THE RINSE CYCLE IS RUN BY THE TIMER, THE TIMER CALCULATES THE TIME FOR THE SIZE OF THE LOAD, IF THE HOSE IS RESTRICTED, THE WATER WILL NOT EVACUATE THE WASHER IN THE AMOUNT OF TIME GIVEN BY THE TIMER, AS A CONSEQUENCE YOUR CLOTHING MAY BE DRIPPING WHEN YOU REMOVE IT OFF THE MACHINE,
GOOD LUCK I HOPE THIS FIX YOUR PROBLEM!
Feb 02, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Timer problems?
LG washer timer displays are only estimates.  The computer is looking at several sensors to determine how quickly the clothes are getting cleaned and how hot the water is.  If the computer determines that things are moving quickly, the timer is reset to complete the wash cycles quicker thus saving energy.
Sep 03, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Which programme saves the most energy?
yes a quick wash is for coloured clothes that have been worn once or twice and dont have bad stains on them.This quick wash will take between 30 and 50 mins to do a wash and is the best programme for the clothing that I have discribed ie: worn 1or2 times and no stains will save you on electric and water peter
Jun 09, 2008 | Zanussi Washing Machines
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
