Battery light but little else
I have a novatech 8889...the battery light is green... when i press the power button on the triangle with a line through it 'light' come on for a second and then the power light came on for a millisecond. There was also a slight tweet, as though the monitor wants to start... Can you help please..
Ink absorber full on a canon mp990 - Canon PIXMA MP990 All-In-One InkJet Printer
Try the following steps. I tried it on my MP990 and it worked.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Jun 02, 2017 | Canon PIXMA Office Equipment & Supplies
How do I fix Canon error message 2700?
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
Thanks.
Feb 15, 2015 | Canon PIXMA Office Equipment & Supplies
How to quit service mode after entering service mode? canon e400
dear
Thanks.
Feb 14, 2015 | Canon PIXMA Office Equipment & Supplies
How do i reset the mp252 cannon printer ink absorber error?
Dear
Thanks.
Feb 10, 2015 | Cannon Office Equipment & Supplies
How to reset canon pixma ip2800 series
dear
  8. Thanks.
Feb 02, 2015 | Canon Office Equipment & Supplies
Error 5B00 in canon pixma MG5370
Hi ..
Try to Reset Printer Ink Obsorber..
Apr 06, 2014 | Canon Pixma iP6210D InkJet Photo Printer
How to repairing for error 5b00 canon mg5370 pixma printer
Hi ..
Apr 05, 2014 | Office Equipment & Supplies
I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
1. Switch off the printer the button Power
2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
3. Holding button Power , release the button Resume
4. Not releasing button Power , two times press the button Resume and release both button.
5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
Jul 09, 2009 | Canon Office Equipment & Supplies
My canon pixma mp140 error 2 and the alarm light blinks. Help me. JJF.
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Mar 09, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
