Question about Sharp AL 1631 Copier
Sharp copier al 1600
Problem H 4
  • annyoungs Jan 27, 2009
    Thank you for trying but it did not fix it.
    Ann
  • 22 Answers
Means low heat roller temperature - the heat roller is a part of the fuser unit, which fixes the toner to the page so it doesn't rub off. This can usually be solved by switching off at the mains for 30 seconds. If this doesn't work try using a "crop code". Put the machine in copy mode. Press # * C * (or # * Interrupt * on some machines) in quick succession. The display should change or go blank. Type in 14, then press start. If it asks are you sure, choose yes. The machine should then restart. If not, switch off and on again. This should clear the fault. If this still doesn't work you may need to replace the fuser.
Posted on Jan 24, 2009
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
SOURCE: Sharp copier AL-1642CS
Here is what worked for me.
You need to alternate pressing the clear button then one of the auto buttons until the display lights turn off.
First press the clear button (red letter “C” on the unit) then the auto button. (below the word auto there are 3 buttons. Press the one on the far left that has no other markings on it. This will only take 2 or 3 times back and forth.
When the display is blank enter the number 14 (like you were making 14 copies of something) then press the Green (start?) button. Let the copier warm up about 30 seconds and try making a copy.
It worked for me. Still having trouble call Sharp USA 630-378-3590 or Canada 905-568-7140. They were quick and helpful
Posted on May 27, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
claudiomn
  • 10 Answers
SOURCE: Sharp Al-1216 Laser copier/scanner but doesn't work on my new Lap
www.sharp-usa.com
Posted on Jan 17, 2009
Sharp Tech
  • 63 Answers
SOURCE: how can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Posted on Oct 15, 2009
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Office Equipment & Supplies
Tip
Follow this link
I hope that helps.
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
SHARP AL-1631 COPIER NOT RESPONDING
try re-installing the software, and re-post if necessary
May 14, 2009 | Sharp AL 1631 Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
Dec 08, 2008 | Sharp AL-1655CS Copier
Sharp AL 1631 Copier Logo
80 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
