Saisho TR60 portable cassette tape recorder not working.
Can you tell me what to use to clean the battery terminals - there may have been very slight corrosion. Although about 10 years old it is is little used and otherwise in good condition. Thans
bmwrider
  • 215 Answers
SOURCE: head cleaning
Quite often just the one clean won't dislodge the gunk built up on the heads. Make sure you use a new wet system head cleaner and you may have to run it a few times to clear the clog. JUST DON'T USE COTTON BUDS OR WOVEN RAGS. BMW
Posted on May 18, 2006
  • 3 Answers
SOURCE: Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Posted on Jun 05, 2007
  • 169 Answers
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
Posted on Sep 07, 2007
ctf1800
  • 4402 Answers
SOURCE: Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Posted on Feb 12, 2008
Maanita
  • 1142 Answers
SOURCE: OLD AUDIO TAPE TRANSFER TO DVD FORMAT
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 24, 2008
Cleaning cassette message
I assume you mean you've got a message come up telling you to clean the cassette recording heads. The camera has detected either that the heads are getting dirty, or sufficient time has elapsed that they could do with a clean. By a cassette cleaning tape - which looks like a normal tape but with white papery stuff - follow the instructions and run it for the recommended time. Hopefully this will cause the message to disappear.
Aug 25, 2014 | Video Cameras
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Have an old Sanyo Mini-Talk Book
hi have you tried to see if it turns without a tape in it as this will then rule out the tape being the problem
May 01, 2008 | Sanyo TRC-3680 Handheld Cassette Voice...
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Camera cassette errors
Often in this situation there are two issues that can casue the problem you are having. 1. The tape is casuing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. Otherwise it may need to be serviced by your local technician. Let me know how it goes.
Jun 27, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
317 people viewed this question
 Grubhead
Grubhead
