Question about IBM ThinkPad A21m 2628 Notebook
Locked out it worked fine until my nephew worked on it, and now when i power up ibm logo comes across the screen and then it goes to a lock symbol. If any one know how to fix this problem I would be grateful.
  • larry shepherd Jul 08, 2007
    Thank you compuguy for your help! Mine is not the first computer Matt has messed up.
  • 432 Answers
Your newphew has password protected your laptop. You will need to get the password from him. Thinkpad BIOS hacking and cracking is big business. Because its next to impossible to break the code. There are thousands of websites that are dedicated to this little lock out function. If you go to Google search and type in 'Thinkpad BIOS Password Reset' nearly 2,000,000 (two million) websites are listed. Now you see where I'm coming from. I found a list of backdoor passwords but I'm not saying they'll work. You can call IBM's hotline from there website, they may know how to do this. The only sure bet you have now is your nephew which I'm glad I'm not in his shoes right now. You can try and research some of the websites and there solutions from the google search. I know these aren't the answers you want to hear but I hope that I've helped you out in some way. Good Luck to You. Standard BIOS backdoor passwords The first, less invasive, attempt to bypass a BIOS password is to try one of these standard manufacturer's backdoor passwords: AWARD BIOS AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet, %????? ?p??????%, %?????? ?p??????% AMI BIOS AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder Other passwords you may try (for AMI/AWARD or other BIOSes) LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME, Syxz, Wodj
Posted on Jul 08, 2007
SOURCE:
My nephew locked my zeepad 7.0. How do I unlock it?
You will need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Nov 02, 2013 | Tablets & eReaders
Can't get past lock code
Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
b>
Feb 05, 2013 | IBM ThinkPad Computers & Internet
CL is coming across the screen. i don't no what to do? i have tried everything from unpluging to cleaning the rubber. also i tried to run with using tide for cleaning and nothing is working. need help.
hi.
CL normally means the child lock is active. look for a lock symbol, either next to a button, or in the middle of a line connecting 2 buttons on the front of your machine. press and hold the button(s) for five-10 seconds until the CL goes off. hope this helps
Aug 16, 2011 | LG Washing Machines
When i start Lenovo thinkpad T400, i get to see a lock symbol with blank screen
Hi sundar1968,
I see that your Thinkpad T400 machine is locked and you are unable to make use of the machine.
to be able to unlock the machine power the system on once turned ON you will see a Lock icon on the center of the screen just press and hold down the FN key for at least 5-7 seconds or if possible untill the lock icons shows that it is unlocked.
This should help you with your concern.
Have a nice day,
mvincentc
May 11, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
IBM Think Vision L170 Monitors. I have a couple with the same issue. Power them on, and the IBM logo flashes for a second, then a blank screen. The indicator LED is green. Powering off/on doesnt...
check for bulging capacitors on the power supply board.if any are bulged their bad.mine was blinking ibm logo i found 2 capacitors bulged i replaced those it works fine.
Sep 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
My laptop is locked and a lock symbol appears on top left corner on the screen
If you press Ctrl + Alt + del, does it bring up an unlock screen where you can enter your password? If not, can you press and hold the power button for 10 seconds to shut it down? Then power back on to restart.
Jan 15, 2010 | IBM ThinkPad T40 2373 Notebook
No screen after the dell startup logo
Thanks-we reinstalled the disc that came with it (it was a used work laptop, no manuel) and it's working fine. Thank you! Lee
Apr 12, 2009 | Dell Latitude D600 Notebook
Can't go to setup, shows a lock and monitor popout
The system password been set in the BIOS. There is no way to clear this. You need to find out who set it. On many systems there is a jumper inside the computer that can be reset but this is not the case with IBM laptops. It is a security feature that requires a new chip to be installed. The only alternative is to return it to IBM.
Mar 19, 2009 | IBM ThinkPad 390X 2626 Notebook
My iphone is not functioning,locked
hold down the home screen button and button at the same time, it will perform a reset. wait until the screen goes black and you see the white apple logo to reappear. when you see the logo let go and it should be fine.
Mar 08, 2009 | Apple iPhone Smartphone
Compaq Presario 1700 Laptop screen flickers and locks up
it sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Sep 05, 2008 | Computers & Internet
IBM ThinkPad A21m 2628 Notebook Logo
376 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
