Question about Denon AVR 800 Audio Video Surround Receiver
Denon avr 800 receiver rear speaker volume control
No rear speaker control from the remote, is there a way to adjust the rear speakers from the main unit?
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
SOURCE: Denon AVR 900
well its possible you have it on stereomode put it on prologic ceneter mode on normal for best sound
Posted on Nov 05, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
SOURCE: denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Posted on Oct 06, 2010
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
How do I adjust the surround sound without the remote?
I was able to find a manual for this receiver at this URL...
http://www.devicemanuals.com/productsupport/Denon_AVR-800_manual.html
Its a free download. I did a search through the file and there is a way to do this. Apparently, the remote for the AVR800 doesn't allow you to adjust the rear speakers anyway, so no problem about no remote.
Hope this helps...post an update if it does or not and I'll keep searching for an answer if not.
Feb 01, 2013 | Audio Players & Recorders
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Feb 04, 2009 | Denon AVR-3805 Receiver
Denon AVR-4802 multi-zone problem.
I had the same questions and still can't believe there isn't more information on the topic. It's crazy how much marketing Denon devotes to their Multi-Zone features yet offers very little reference materials on the actual set up. I guess most customers don't use the fearture? Here you go:
-The Multi-Zone on the Denon 4802 is analog only. If you are running digital coax or fiber you will have to run a second line that's analog (eg RCA red/white) from the source to the Denon in order for the signal to to make it to the Zone 2 speakers (regardless if it's Pre-Amp out or direct connect to the Zone 2 speakers from the multi/SB speaker outs. Regarding the Harmony question, I had the same problem with my Harmony 880 and wasn't able to find an answer after multiple searches. Luckily I figured it out when I deleted the receiver from the Logitec device list and started over. Connect the remote to your computer, launch the Logitec Harmony Remote Software, click the Devices tab, hit the Add Device, pick the device type & manufacturer from the drop down list, enter "AVR-4802" under Model and finally hit the Next button in the lower right corner of the UI. The next page solves the Harmony Zone 2 control problem. You will see a message "To use your device in additional zones/rooms, click the checkbox...." Make sure Room 2 is checked (mine was not), update the remote and you're done. The Harmony Device menu you will now contain a second receiver icon called "receiver 2." Hit "device" on the Harmony, choose "receiver 2" and you will gain control over Zone 2 including volume.
Steve
Jan 21, 2009 | Audio Players & Recorders
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Denon avr-2500 left main speakers very quiet.
The Denon 2500 was one of the best ProLogic receivers built, it was a work horse and very little ever went wrong with them.
To make sure you're only supposed to hear right & left speakers, press the Stereo button on the remote. Also recheck your speaker connections - this is the single most overlooked connection problem folks have.
Check the balance control to make sure it's in the center position
Make sure the Tape Monitor is not engaged.
Then, check to make sure that the Pre-Out, Main-In jumpers are connected properly on the rear panel.
If that is not the problem, try pressing the Tone Direct button on the remote (aka Tone Defeat on the front panel).
Jul 26, 2008 | Denon AVR-2500 Receiver
Denon AVR 900
you need to put the volume up on those speakers you can only do that with the romete s you kinda stuffed unless you get the remote.
Aug 13, 2007 | Denon AVR-900 Receiver
Denon AVR 800 Audio Video Surround Receiver Logo
69 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
