Question about Tissot PRS 200 Wrist Watch
What are the numbers on face plate for(likes 60,65,....900,1000)?
How to use or read those numbers? The watch is TISSOT PRS200. Thank you very much.
    New Friend:
The numbers are for speed in km/h. if you're in a car and you use your chrono to measure how long it takes for the car to travel 1km, when you press stop, the resulting number is the current average speed your car or whatever vehicle is travelling at.
eg. if it took 30 seconds to travel 1 km then your average speed within those 30 seconds is 120km/h
Posted on Mar 05, 2013
    Problem Solver:
  • 11 Answers
The ones associated with the little circles? One dial is for seconds, one for minutes, and one for hours. The seconds one should be applicable for time. The minute and hour, along with the big seconds hand that is centre mounted are for the chronograph function.
Posted on Feb 16, 2009
Need the dial on a tissot prs200 fixed/replaced, what is the cost???
You will need to go to several watch repair places to get estimates.
Jan 19, 2013 | Watches
Can i get an extra link for my tissot 1853 (prs 200) bi metal,the strap is to tight, and will not adjust anymore.
I need one link for my watch that was given by my daugther its tissot diamond t shape stainless steel case,mop dial
Oct 26, 2012 | Tissot T Touch T33158851 Watch
How much is the cost of replacing a battery on my tissot prs200
If you have tool and do it at home, it costs you about $4.00 for the new battery bought from Wal-mart. You have to open the watch's back to see the battery type (for example Renata or Maxell or Varta, etc. together with a 3-digit number) then go to Wal-mart or somewhere else to buy a replacement.
If you can't do that by yourself or don't want to get some scratches on your watch, bring it to your local watches/jewelry store. ( I have paid for that small job $16.00 plus taxes.)
Feb 16, 2011 | Tissot TSport PRS200 Chronograph T17148644...
Hi, I've got a broken spring bar on my Tissot PRC 200 and would like to replace it. I understand that it has got a lug width of 19mm. Does that mean I should buy a 19mm spring bar, or should it be a...
Two of the spring-bars broke on the clasp of my PRS200, so I took it to an un-named watch repair shop that was closer than the Tissot-authorized store (Leslie Gold Watch Co.) at which I bought the item 5 years prior. After the repair, the clasp kept popping off, so I took it to the Tissot store, and they told me that it was because the ends of the bars didn't fit properly. They replaced the faulty bars for me at no cost, and the watch has been sitting on my wrist fine for the last year-and-a-half.
Dec 15, 2010 | Tissot Watches
My prs200 watch stops now and then... replaced the battery but still continues to have this problem
Even the best watches need servicing time after time. Obviously there is no battery fault, but something related to mechanics or electronics in your watch. Get advice from watch repairer.
Nov 22, 2010 | Tissot PRS 200 Wrist Watch
Don't know how to remove the links on my prs200
mcdevito75 here, Best Bet look for a small watch repair shop in your area to save money on cost. You"d need a special tool called a link remover tool available on ebay but you can also wind up destroying the band, and a tissot band is expensive, let the shop remove the links.
Jun 23, 2010 | Tissot PRS 200 Wrist Watch
What battery and used in tissot prs200
The battery for a Tissot PRS200 is a "RENATA SR936SW (394)" & all you need to replace it is watch back wrench about £4 (ebay), dot listen to the jeweler trying to bill £45 its an easy 5min job
May 05, 2010 | Tissot PRS 200 Wrist Watch
How do I change the time on the tissot 1853 touch watch
  1. Locate the screw on the side of the watch face. This screw is what you will use to set the time on your watch. Water-resistant watches have a screw-type crown, and the screw must be turned toward the body (unscrewed) before it can be pulled out for further use. If the watch is not water-resistant, the unscrewing is unnecessary.
  2. 2 Pull the screw gently outward. The screw can be pulled outward in two positions. The first position sets the date and day. Pull the screw out farther (into the second position) to set the time.
  3. 3 Turn the screw either clockwise or counterclockwise to move the minute and hour hands to the desired time. Push the screw all the way in (and turn it away from the body if you have the water-resistant model) when you are finished.
    Digital Watch
  4. 1 Locate the three buttons on the side of the watch face. These are the buttons used to set the time. The top button is the "+" indicator for increasing the numbers. The bottom button is the "-" indicator for decreasing numbers. The center button is to activate the setting mode.
  5. 2 Press the center button in for one second. The watch will beep.
  6. 3 Press the top "+" button for two seconds. After the watch beeps, you can begin setting the time.
  7. 4 Press either the "+" button or the "-" button (depending on whether you want to increase or decrease the numbers) to set the time.
  8. 5 Press the center button when you are finished. The watch will beep. This validates the setting. The seconds will revert to zero.
Read more: How to Change the Time on Tissot Watches ' eHow.com http://www.ehow.com/how_5934972_change-time-tissot-watches.html#ixzz14ifvni46
Nov 04, 2009 | Tissot T-Touch T33159851 Wrist Watch
Tissot prs200
I also own a PRS200. The sub dial at the top left shows the minute count when you use the chronometer function. In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Dec 23, 2007 | Tissot PRS 200 Wrist Watch
Tissot PRS 200 Wrist Watch Logo
306 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
