Question about Dell Precision T5500 PC Desktop
How do i install a 2nd internal hard drive on my dell precision t5500
I have my 2nd 3.5 inch SATA hard drive to install on my dell precision t5500, and need to know if there is anything else I need to do besides just plug and play. Example, enable something?
    Top Expert:
  • Dell Master
  • 42,927 Answers
You don't mention it but you might be asked for an installation disc, especially if plug and play doesn't work
Posted on Jan 14, 2013
sandrew
  • 2961 Answers
SOURCE: Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Posted on Sep 01, 2008
  • 205 Answers
SOURCE: Dell Precision 380
So the 80GB drive is an IDE drive, right?
Different manufacturer's have different BIOS' so I can't say with certainty what you'll see in yours, but on my ASUS motherboards I have a one of three settings:
PATA
SATA
PATA+SATA
When I run both IDE and SATA drives I need to use the third setting. I sounds like you're shutting off the PATA when you enable the SATA so there's no drive from which to boot.
If I misunderstand your problem please let me know.
Posted on Dec 22, 2007
xerick
  • 139 Answers
SOURCE: Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
Posted on May 23, 2008
kikoksky
  • 119 Answers
SOURCE: Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Posted on Jun 20, 2008
MDoe
  • 156 Answers
SOURCE: Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Posted on Aug 21, 2008
Sata driver download
Check your motherboard manufacturer's website. Sata drivers are not hard drive specific, they have to do with your motherboard. If your computer was pre built and you are simply upgrading it, check your pc manufacturer's website (Dell, HP etc.)
Sep 03, 2014 | Dell 2TB 7200RPM SATA 3Gbps 3.5-inch...
Booting Problem
Not sure if this model computer supports SATA drive interface. It uses IDE interface for hard drive. Here is a link to your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dell_precision_workstation/precision-650_Service%20Manual_en-us.pdf
Feb 13, 2013 | Dell Precision 650 PC Desktop
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
I cant get my Dell Precision 690 to recognise a hard drive
Double check the bois to ensure you have all the Sata ports turned on. I have found in some Dell computers the only ports turned on are the ones in use when shipped from the factory.
Feb 01, 2012 | Dell Precision Workstation 690 - 750W...
I see no evidence of a place in which to insert a cd to copy/burn in my new inspiron 580
According to dells, admittedly unhelpful store. The optical drive is an optional extra... Unfortunately this isn't of much use to you, if there's really no drive in the machine you'll ahve to either try and return it, or purchase one.
If you decided to purchase one you could go for an internal or external drive. An internal one would be slightly cheaper, however you'd have to install it yourself.
There are some pretty cheap options on ebuyer.
http://www.ebuyer.com/search?page=1&store=33&cat=27
Best of Luck
Jun 11, 2011 | Dell Inspiron 580 PC Desktop
For 2nd int. hard drive ? SATA or IDE -HP Media Center a1640n
You can contact your vendor. Or at ebay
( http://computers-networking.shop.ebay.ph/Computers-Networking__W0QQ_sacatZ58058 )
copy an dpaste the link your Internet browser address bar
melnavz
Feb 23, 2009 | HP Pavilion a1640n (RC663AA) PC Desktop
Connecting a 2nd internal hard drive
No, the Y cable will not compromise the function of your master drive. As far as the fan goes, a 2nd hard drive is not going to increase the internal temperature at all; the fans that came with your system should be sufficient. Thanks and please take a moment to give this answer a rating of fixya. Thanks :c)
Feb 18, 2009 | IBM Computers & Internet
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Precision T5500 PC Desktop Logo
1,160 people viewed this question
Alun Cox
