Question about AOC LM729 17" LCD Monitor
AOC 716Vwy LCD Monitor sound problem - AOC LM729 17" LCD Monitor
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
webdevil
  • 43 Answers
SOURCE: aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Posted on Jan 06, 2009
budmrtn
  • 11361 Answers
SOURCE: AOC LCD MONITOR
The cable from the Monitor USB input to PC USB output is good? Check to see if you do have 5vdc on pin 1 of the USB connector. Your monitor is basically a powered USB hub when it is connected to PC through a USB cable.
Posted on Jan 20, 2010
budmrtn
  • 11361 Answers
SOURCE: My AOC 2019Sw1 - 20" LCD monitor is not working.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 01, 2011
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
How do i turn the sound up on my aoc monitor
This monitor includes very low-volume speakers (2x1W), so you might need to connect external speakers if you require higher volume.
May 02, 2011 | AOC 2036sa 20"TFT LCD Monitor
I have aoc lcd monitor, but no display and always orange the swicth botton. what is the problem of my lcd? can you help me? thanks..
It sounds like there is no signal to the monitor. The computer you have, does it work if you hook up another monitor? Have you taken this monitor to maybe a friends house or neighbor? See if it works. If it does; there may be a problem with your computer's video. If the monitor does not work; the issue is the monitor. It will then need to be replaced.
Jan 29, 2011 | AOC 193FW LCD Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
I can't find aoc 210s drivers. Where can i get
Please follow the below link
http://www.voiceofchinese.com/techs/aoc-210s-2210s-lcd-monitor-drivers-for-windows-xp-vista
Please download the drivers from below link
http://www.voiceofchinese.com/files/AOC-210s-2210s-LCD-monitor-driver.7z
I believe your problem will be solved
Sep 04, 2009 | Computers & Internet
AOC LM729 17" LCD Monitor Logo
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
