  • 144 Answers
There should be a chart or list on the inside of one of the panels that says what the fault codes mean. Check it out and report back. Maybe we can be more helpful.
Posted on Jan 23, 2009
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
No heat blinking light 4 times trips reset button
It may be either a blocked chimney or a blocked heat exchanger. If you have an air compressor you can try blowing out the heat exchanger. Using a shop vac also works or both. Using the air compressor to blow out the heat exchanger and the shop vac to vacuum up what comes out. A lot of the time these units are in places were mice and other rodents can get into them and build nests or store seeds or whatever in the exchanger part of the heater. If the exchanger or vent are even partially obstructed the flame doesn't get pulled through the exchanger well enough and heats up the rollout switch causing it to open.if there is no vent terminal installed on the vent a strong wind can also cause the same thing. Hope this helps.
Dec 13, 2013 | Dayton (4LX44) Gas Heater
The wind keeps on blowing out pilot light in the Intertherm Gas Furnace
The wind is probably not the culprit here. You probably have a crack in the heat exchanger, which allows the air from the blower to escape and blow out the pilot light.
Oct 31, 2013 | Intertherm P3RA-048K Air Conditioner
Goodman heater red light blinks 5 times is a blower heater, it says is the sennsor flame, i keep changing it but it keeps burning it over and over doesnt work
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering
Nov 05, 2011 | Goodman GMS90703BXA Heater
Heater not working
What does that mean? It blows air but not hot air? It doesn't blow air at all with A/C or heat? I assume you mean it blows, just not hot. If so, make sure your car is running at operating temp. If the car isn't warming up, your thermostat is stuck open and the coolant can't heat up enough to transfer heat from the heater core to the air you're blowing out the vents. If your car warms up to operating temp just fine, you may have a heater core issue. Your core may be clogged with corrosion thus not allowing heat transfer as well. If the valve on the inlet hose to your heater core is bad it won't allow hot coolant into the heater core, once again no heat to the air blowing out your vents. One of these is most likely your issue. I hope this helps.
Feb 03, 2010 | 1995 Ford Escort
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Oct 22, 2008 | Goodman GMS90703BXA Heater
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
