Question about Canon ImageRunner 2270 | IR2270 |
Canon iR2270 cause E602-0001. Hard Disk check mode (holding 1 and 9 when switching on) can't fix problem - machine enters in "download mode". Help me please!
    Problem Solver:
  • 10 Answers
Some times it does not work and u have to need replace ur hard disk
Or u can try * 28 holding when u start the machine and also *19
Posted on Jan 16, 2013
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
Tip
Xerox machine ir 3320, error 602-003 and 602-004\r\n
The E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem. try this, hold on 1 and 9 (from the machine key board) then switch on the copier; then wait around 1 hour all screen will be white then the copier will display download mode. then switch off and put on the copier.
on Nov 02, 2010 | Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
Please help me a reset key for the copier machine IR2270 wich read error code E000000-0001
The abnormal rise of temperature.May be main thermistor or dc controller pcb.You have to reset the machine in service mode COPIER FUNCTION CLEAR ERROR.
Oct 30, 2014 | Canon iR2270
I have canon ir2270 it's connected through a usb cable. how can i scan a document?
To scan any document with machien first of all u have to need connect ur machine with ur compuer via cross cable,
Dec 29, 2012 | Canon ImageRunner 2270 | IR2270 |
I have a xerox machine ir 3320 i have facing a error 602-003 and 602-004\r\n and printing are coming zigzag type
try this,
then wait arround 1 hour all sceer will be white then the copier will display download mode.
Oct 31, 2010 | Canon Office Equipment & Supplies
Canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
May 21, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Konica Minolta bizhub reads "server disk full": how to unfill server disk? or how to fix?
CAUSE: Machine memory is corrupt and the max out time needs to be increased.
SOLUTION: Perform a Data Clear:
1. Enter the Tech Rep mode.
2. Press System 1.
3. Press Initialization.
4. Press Data Clear.
Also browse to the NIC, enter Admin mode and set the connection timeout for E-mail to 300 seconds.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Canon ir 2200 help
For problems with the hard disk on the Canon ImageRunner (my model is 2220n):
Step 1: Unplug the unit (leaving power switch on), and then plug back in while holding down the 1 and 9 keys
Step 2: Wait. The hard disk will reformat - you should see at first a flashing white block in the upper right hand corner, then you will see white blocks building rows on the screen left to right with the screen eventually filling entirely. This may take an hour or more.
Step 3: After reformatting, your screen should say "Download Mode" at the bottom. Now just turn the machine off, unplug it for a few seconds, plug it back in, and then turn it on (you must switch power toggle off and then on - not sure if unplugging is necessary but it worked for me).
This site is great and has saved us at least $1,000 on copier repair this year - repairs that really didn't require a tech at all.
Good luck.
Jan 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRunner 2270 | IR2270 | Logo
452 people viewed this question
old marine
old marine
