I have a discontinued battery operated portable cassette tape recorder, Saisho TR60, little used. The batteries had very slight corrosion which may have affected the terminals in the recorder. Can you tell me how to clean them? (They're tricky to get at.)
    Genius:
  • 1,199 Answers
I find it best to wrap a piece of fine sandpaper around a bendable wire and gently rub over the contacts!
Posted on Jan 23, 2009
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
Have an old Sanyo Mini-Talk Book
hi have you tried to see if it turns without a tape in it as this will then rule out the tape being the problem
May 01, 2008 | Sanyo TRC-3680 Handheld Cassette Voice...
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
Audio cassette tape broken. How do I repair?
Radio Shack used to sell a splicing block and tape for fixing broken tapes. They may still, and you can order online from other sources.
You need to pull the tape out from the cassette a little way. Overlap the tape sections a little and get them aligned, which is what the splicing block is for. Cut across both pieces and take away the scraps. This makes sure the pieces match up. Lastly you place special splicing tape over the join and trim the edges. You need the special tape, since it's designed so the adhesive won't ooze out and get on the tape recorder heads.
If the tape has come loose fro the hub inside the cassette, you need to open the housing and use the splicing tape to fasten the recording tape (actually the plastic leader tape) back in place. Depending on how the cassette was made, there may be screws holding it together, or it may have been glued. Some commercially-made music tapes and bargain-grade cassettes weren't made to be opened. If you do open the tape, don't lose the little metal piece with the felt square that goes across the opening behind the tape. This is the pressure pad that keeps the tape pressed against the head in the recorder. Without it, the tape won't work properly.
Apr 12, 2010 | Electronics - Others
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Mar 31, 2009 | Sony Walkman WM-D6C Personal Cassette...
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
 Grubhead
Grubhead
