Is my TSSTcorp TS-H653Q (dvd brrner) an ATA or SATA type
I need to replace my burner but I'm confused if the one I have (TSSTcorp TS-H653Q (dvd brrner) is an ATA or SATA so I know which to pruchase. Search reveals conflicting results.
    Top Expert:
  • Computers & ... Master
  • 35,737 Answers
Inspection of the rear connector will reveal the answer. A SATA drive has a thin cable; an ATA drive cable is thicker (more pins)
Posted on Jan 14, 2013
  • Shift Happens Jan 14, 2013
    Thanks Tom for your quick reply.
SOURCE: How to replace my DVD drive?
well if you are going to buy one, i would go to www.newegg.com and see what they have. I am also assuming that you are comfortable opening your computer. When you get a new DVD drive open up your computer and look how the old one is connected(i would do that before you buy a new drive too) and if your connects the way i think it does it should have a ribbon (bunch of wires attached together in a line) that have a rectangular thing at the end that connects to the back of your drive and also it will have another set of wires that are multicolored that come from your power thing it will have 4 wires that connect to the back of the DVD drive, make sure both the ribbon and the power cables connect correctly to your new DVD drive. if they do great, you now would only have to take out the old drive and put in the old one(they usually attach to the computer case via screws on the side of the drive) once the old is out and the new is in you just plug in the cables(ribbon and power) and it should work.If the cables arent the same see if you can return it for one that would fit correctly. If you have any questions about my explanation ask (i am new to this and not all that great at giving organized instructions)
Posted on Mar 16, 2009
  • 1257 Answers
SOURCE: Code 39
Follow this article to fix the issue..
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on May 26, 2009
pumpkinman
  • 1144 Answers
SOURCE: working device (DVD/CD rom burner/reader) not reading disks
try rolling back the driver
Posted on Jul 01, 2009
sandro_monte
  • 72 Answers
SOURCE: OPTIARC AD-5170A DVD BURNER & VISTA FAIL TO FORMAT DVD-R DISKS
optiarc ad-5170a is for dvd-rw only
Posted on Oct 11, 2009
Testimonial: "HI ! SANDRO MONTE,THANK YOU VERY MUCH. HOW COULD I KNOW THIS DETAIL ?!"
  • 80 Answers
SOURCE: UNKNOWN ERROR 2130932483
Usually means the media is not compatible or is caused due to a bad disc...changing the disc will eliminate the problem...it may be due to a bad brand of disc as well. Look at your disks are they + R or - R, Some burners even though they say +/- they have problems with + R disks and others with - R. Nero 7 and Realplayer have nothing to do with your problem. Try changing your media brand, I have good results with Sony.
Also burning to a folder then disk helps with this problem.
Posted on Oct 21, 2009
I have this message " SATA CD :: TSSTcorp CDDVDW TS-U633J" What does it mean?
SATA : Serial ATA, the type of interface for the Drive as opposed to IDE (the older type.).
TSSTCorp is a joint venture Toshiba Samsung for Optical drives
CDDVD R-W CD and DVD Read Write.
TS-U633J is the model number. That is the reference you use if you are looking for drivers.
Why did this information get you worried?
Oct 27, 2013 | Samsung NC10-14GW Notebook
Need driver for TS-H552L
check this link http://forums.driverguide.com/showpost.php?s=8a47ea3685bcafd636f95b07c7e2ca87&p=63965&postcount=2
Here is the driver: http://download.driverguide.com/driver/TS-H552L/Samsung/d1595684.html
Dec 17, 2011 | Samsung Computers & Internet
My TSSTcorp TS-H653Q (dvd brrner) can't read cd, games or dvd. The drive appear on my computer(C:) but it cannot detect any disk inside... is there a driver problem or a compatibility with my OS? i use...
Go to Control Panel -> Hardware and Sound -> Devices and Printer -> Device Manager -> locate DVD/CD-Rom drives and 'Uninstal' the driver for your TSSTcorp drive to force a re-install of the driver -> Go to the very top of the device manager tree (where the computer name appears), use the context menu and 'Scan for Hardware changes' -> this will re-install the DVD driver.
Hopefully this will solve your issue. If it does not, and your drive is 'old', then you have a possible defective drive (the laser unit does not last for ever and is usually the issue - it is not worth repairing the unit).
Hope it helps and let me know how you go: good luck!
Sep 27, 2010 | HP Computers & Internet
What DVD burner should I put in my Dell E1505 Laptop
I'd get a double layer (dl) drive by Memorex from either Tigerdirect or NewEgg. They always have them on sale and all three of my systems have one installed.
Good luck,
BW
Nov 12, 2009 | Dell Inspiron E1505 Notebook
Tsst-h652d not working after upgrade, thinks its a cdrom not combo
Well, I'm sorry it didn't work out for you. It was still worth a try. I have to agree with you. Since it isn't being recognized properly it probably isn't worth the trouble getting it repaired since typically that costs more than buying a new one. If you need to find some good prices on CD/DVD readers & burners you can look online here:
Newegg
Simply navigate to Computer Hardware > CD / DVD Burners & Media. After the page loads simply click, "CD / DVD Burners" located in the menu on the left.
Let me know if I can do anything else for you (posted as a solution so you could rate the responses above).
May 27, 2009 | Gateway GT5408 PC Desktop
My TSSTcorp CDW/DVD TS-H492A driver is not reading DVDs
my tsst corp cdw/dvd ts-h492a is not reading any dvd's how do i fix this problem without having to spend $29.99 for another program?
where can i download the drivers for this drive?
Nov 14, 2007 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
