Question about Dell Inspiron 1000 Notebook
Will not turn on
Some lights come on when laptop plugged into power adaptor - if tap on the pc beside the on/off switch occasionally begins to start up but will tend to cut out. Heard this could be a processor problem or a motherboard problem?
  • sammydad1 Jan 27, 2009
    I am working on the same problem. My battery is totally **** so I can't be sure it isnt part of the problem.
    One thread i saw mentioned opening the top ALL the way open so the screen is flat, and then trying to power on....
    I am not if it really is a motherboard isue or a **** battery issue or a power adpater issue or some combination of the three...or something else all together. I got it to boot after "charging" the battery for almost a day, but MAN was it HOT, the battery that is...I was afraid I might burn myself.
    After XP booted, it showed it had like 11 Hours of charge at 50% so obviously it is way out of calibration. When I tried to calibrate within the BIOS, it kept saying the AC adpater was not plugged in, which it was..... so now it added more confusion to the process...
    Scholar:
  • 157 Answers
Just check first the power consumption in the motherboard..you dissamble the laptop remove motherboard and check the power supply area of motherboard if the current goes in, is the same as the voltage of your laptop...check with the digital meter..
if not the same, you can replace first the power jack before anything else..because the processor cant be damage like that only,maybe i will believe for the mainboard but processor...its hard to damage..unless you will broke the pin....this idea based on my experience only....
Posted on Jan 31, 2009
I press the power button, and only flashes twice, nothing in the laptop turned on or starts
Try with the AC adaptor connected and plugged in. It may be a faulty battery or something more serious. Make sure the power light comes on when the charger is plugged in and switched on. In the evenit is still the same let me know.
Jan 31, 2012 | Dell Latitude D620 Notebook
Does not start; no power indicator light
Take out the battery and then try the different ac adaptors. If you still get no lights on the laptop then the motherboard is bad and would need to be replaced. Just make sure that you know at least one of your ac adaptors are good.
If the adaptors have lights and they turn on then you know the ac adaptor your working with is good. Also make sure they are plugged into a good working outlet.
May 29, 2009 | HP Pavilion ze2000 Notebook
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
May 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Dell 610c will not turn on with adapter
yes the ac adaptor in the unit is defective they short out you will have to replace it the part is only 9.00 but labor can be expensive. thank you james
Aug 26, 2008 | Dell 2600 Notebook
Laptop not showing light, power button not turning on, AC adaptor light constantly beeping faintly
Unplug the power cable... Hold the power button down for 15-20 seconds... Plug cable back in and check for light... If this still didnt work, then unplug cable again, take battery out, wait 10 seconds.... Put battery back in, plug cable back in and this should allow you to boot...
Feb 05, 2008 | Acer Aspire 3680 Laptop
Possbile battery
It could be a battery fault, have you tried it without the battery?
Sep 07, 2007 | Acer Aspire 3680 Laptop
Dell Inspiron 1000 Notebook Logo
54 people viewed this question
Alun Cox
