Question about Kodak ESP 9250 AllInOne InkJet Printer
Kodak aio esp 9250 will not print please help
I have changed print head and put new ink in. Calibrated the print head and it shows ink and print head found. But it still will not print. HELP
  • 826 Answers
Try to Reset the cartridge..
Posted on Jan 14, 2013
Testimonial: "This helps, but I need to know how to reset the cartridge. Thank you"
  • Daniel G Printz Sr. Jan 17, 2013
    How do you reset the catridge?
  • 518 Answers
SOURCE: Kodak esp 3 all in one. colour prints come with purple tint
Surely you can turn the flow of ink down via your settings
Posted on Jun 14, 2009
  • 295 Answers
SOURCE: kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Posted on Jan 01, 2010
don_farr
  • 1011 Answers
SOURCE: Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Posted on Feb 27, 2010
  • 15 Answers
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Posted on Apr 17, 2010
SOURCE: kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Posted on Nov 27, 2010
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
Kodak printers 7 and 9250 esp not printing.
If you do not print weekly with a Kodak printer, the ink can dry inside the heads and they stop printing. I have had this happen to two of my Kodaks. To prevent this, if you are not using them regularly, print a test sheet weekly and you should have no problem. At this point, your best bet is to order new heads for your printers and then maintain them with weekly test prints.
Mar 31, 2014 | Kodak Office Equipment & Supplies
Installed new ink calibrated prints like they are negatives
First Check For Setting in the software and if problem persist the change cartridge.
Jan 01, 2013 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak esp office 6150 printing blank pages
Here's how I fixed my Kodak AIO 6150.
  1. 1. Remove cartridges
  2. 2. Remove the print head - lift up on the grey tab just above the bullseye - it'll pop right out - no tools needed.
  3. 3. Soak in alcohol - NOT RUBBING alcohol - Isopropyl 91% only for 1-2 hours - shake often.
  4. 4. Let it dry for at least 2-3 hours.
  5. 5. Reinstall everything. You'll get a new printhead message.
Dec 07, 2012 | Kodak ESP Office 6150 All-in-One Printer
Kodak 5250 with lines going through images
Unfortunately, you will probably need to replace the print head unit if cleaning the print head did not help you. Changing laptops will not be related to your problem.
Jul 25, 2012 | Kodak Esp 5250 All-in-one Inkjet Printer
I was only getting the bottom half of printed words. Ran test pages, alignment, clean printheads. These inks are brand new. It also did it with my other inks which is why I replaced them. I have Kodak...
Cleaning the print-heads is the correct action to take -- if the ink-jets are clogged, then the ink (in either old or new cartridges) cannot be sprayed onto the paper.
Note that the print-head has multiple jets -- like painting across a wall with a wide paint-brush.
So, if you don't have paint on the top half of the brush, then only the bottom half of each row on the wall will get painted.
Try some more head-cleaning cycles.
Jun 25, 2011 | Kodak ESP 5 Printer
Black ink printing incorrectly. Blank lines are showing in the middle of a line of printing. I have cleaned the print heads, alligned and calibrated. Nothing seems to work. In fact, calibrating made...
Hi
Try to clean it manually by removing the ink cartridge and then clean the print head with softcloth with rubbing alcohol. Then rub again the printhead into a plain paper until ink flows. Then try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 20, 2011 | Canon MultiPASS MP370 All-In-One InkJet...
My Kodak 3250 printer is printing very faded. I've changed the ink cartridges, even taken out the print head itself and cleaned it with alcohol. Calibrated it several times, print head aligned it several...
First if you used ALCOHOL on the print heads you most certainly made some DAMAGE because alcohol will MELT the microscopic electronic nozels, the best way to clean a jet ink head is to soak it into WARM WATER NOT ALCOHOL, if your lucky you could try soaking the head in warm water for 30 minuts, than VERY DELYCATELY dry it with a scott towel, than use GENUINE KODAK INK not generic or re-filled ink cartridges if all that does not work, well you probably need a new print head
Jan 12, 2011 | Computers & Internet
Kodak ESP 9250 AllInOne InkJet Printer Logo
590 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
