Question about Moen Home
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
This seems to have started happening not long after I changed one of them stems in the shower, but not immediately after. Even after the hot water dies in the shower, there is hot water in the sink in the same bathroom and everywhere else in the house. It's like the hot just disappears. I turn the cold all the way off and cold water continues to come out.
    Top Expert:
  • Moen Master
  • 43,979 Answers
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Posted on Jan 14, 2013
Testimonial: "That seems to have been the issue. Thanks for the help!"
2 Suggested Answers
  • 182 Answers
SOURCE: I jhave in my showers
As you look at your valve on the right you will see a large screw fitting.inside this fitting is a temp/ pressure balance spool. it has failed for some reason and needs to be replaced. On both sides of the valve are 2 smaller screws. these are the water shut off valves. turn off the water and remove the larger screw fitting. remove spool and replace. Hope this helps.
Posted on Dec 21, 2010
Water temperature has reduced even on maximum setting
check tap had a shower myself that would start hot then 3 minutes later hot was cold! then hot after 5 minutes.
I turned off main tap on meter, Undid tap fitting on shower found the washer was worn but also the tap fitting was seized could not turn it for full movement. You could soak the tap screw fitting in CLR and pull apart and use a tap grease on the screw thread or just buy another tap fitting. I discovered most of my tap fittings had calcium build up in them. But I replaced the shower tap valve thingy as it was really seized up.
Nov 22, 2015 | Home
I went to take a shower this morning and the water was ice cold. For more than twenty minutes the water ran and never warmed up. Are there common things to check my hot water heater for in this situ
There is an adjustment knob to control how hot the water can become. There might be a problem at the tap (however, if this is the case, you would still get hot water everywhere in the house). If the entire house isn't getting hot water, and the knob is set at the hottest water, you probably need to get the hot water tank replaced.
Feb 04, 2015 | Rheem Tankless Hot Water Heater...
Rheem warrior 40 gal warrior
You could start by seeing if the thermostat is wide open. Sounds like it is on low or vacay mode. How far is the run between your heater and the bathing area. Might need to insualet some piping.
Sep 24, 2013 | Water Heaters
Vanquish shower goes hot and cold sometimes
Are the pressure ballance taps? If the shower is on and someone flushes the toilet the water will get hot in the shower,if they are not pressure ballance taps,or if they are the cartridge needs to be replaced in the tap.
Apr 18, 2013 | Home
The burner on the heater is working bu can't get water to stay hot at the faucets or showers water turns cold right away. whats the problem?
Test for crossover, where bad faucet cartridge or recirculation check valve keeps hot from reaching taps
http://waterheatertimer.org/Crossover.html
Add a comment and say what you find
Feb 28, 2013 | Rheem Water Heaters
We have a neptune bar mixer shower that has been fitted to the wall and plumbed. All the water has been turned back on, the hot water is working fine but nothing is coming through the cold water side. cold...
Possibly switch off hot and cold water then undo cold water flange closest to the outlet and see if water comes out.if it does, tap assembly is faulty. If not, go back to where next available connection to the pipe was made. Work back untill you find the problem.
Aug 05, 2010 | Home
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
Home Logo
433 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
