Question about GE Refrigerators
Gsh25isxl no water from dispenser - GE Refrigerators
Replaced water dispenser still not moving or getting water
sad but we can not look it up as were not given make or model
Mar 26, 2015 | Refrigerators
My water dispenser in my GE Adora stainless side by side refrigerator is not working
Water dispenser doesn't work
  1. Dispenser control board
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
  1. Water tube in door is frozen
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Why is my Water dispenser not working?
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Refrigerators
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Just installed a new Bosch fridge, ice dispenser dispenses ice but water does not dispense?
Make sure it has water on the container and no obstruction on the water dispenser. Try several times. Since it was new unit, sometimes water has not yet completely fill the dispenser tubing hence it will not dispense water.
Look for some carton, foam or plastic obstruction around the dispenser, it may cause hindrance of not flowing water from dispenser into the glass.
Thanks for asking.
Jul 03, 2011 | Bosch Refrigerators
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Water Dispenser
water fill valve or if equipted need to cnage water filter
May 06, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
