Question about Home
Bubbles coming up and making noise - Home
  • 979 Answers
Your vent on top of the house is clogged. This vent allows water to flow naturally and not build up pressure. It in other words breaks the vacuum that naturally occurs. The vent should be free of any debris or trash.
Posted on Jan 30, 2013
My boiler is making a whirling noise after I topped up low pressure. Heating and hot water are fine.
You have air in the pump-you need to keep input pressure up and open drain on output side of pump until no bubbles come out-cheers Denny
Oct 13, 2013 | Heating & Cooling
How to take the air out the power stering pump
It may sound awful but the best way to do it is to get a buddy and some extra power steering fluid. With the car running slowly rotate the steering wheel side to side. Have your buddy keep an eye on the reservoir to make sure it stays full. The air bubbles should come up into the reservoir and make it look foamy. Once the noise tops and the bubbles stop rising top off the reservoir and make sure it is to the full line and you should be good to go.
Nov 18, 2012 | 1998 Lincoln Continental
Mspa camaro bubbles not working.I pressed the control panel, light comes on and a clicking sound comes from unit but nothing happens
Mine is the same I press the bubble and the light comes on like it's working but no air is coming out what can I do so so mad
May 13, 2012 | Pool & Spa
Theres a growling noise coming from my power steering
The pump is low on fluid . If fluid level is a-ok check for foam and bubbles in the resvoir. If there is foam and bubbles drain and bleed the resvoir according to spec's. If after all this the pump still growles you may have a bad bearing but before you condem the pump, few more checks you can do. Before I go there lets see how you make out with the foaming and bleeding. Good luck
Mar 05, 2010 | 1998 Ford Explorer
We bought a new 41 inch viking grill. Hooked up LP regulator and tank. When we light the burners there is a loud humming noise that is coming from the regulator and/or hose (we have reassembled twice to...
First make sure everything is tight on the valves if you still smell it get some windex spray where you hoses, the tank where it connects places where the propane gone if it bubbles you have a leak for the noise turn the tank upside down and shake it for about 10 second
Jul 12, 2009 | Viking VGBQ532-3RT All-in-One Grill /...
Fan is working but when switched to cooling the motor is making noise and there is no cool air coming out
Loose wiring, capacitor defective,loose compression in motor or depleting/no refrigerant in the system due to leak or hole in the system.
Apr 17, 2009 | Heating & Cooling
Washer pump has packed up how do i reach it to replace
yu need to change the water pump out. if its backing up into the reseviour then its not working right.
Feb 21, 2009 | Hyundai Motor 1998 Accent
Power steering pump is clicking and whining
It sounds like the power steering hydraulic system has air in it, causing the pump to whine and the bubbles to show up in the fluid. The clicking noise is probably just the power steer pressure switch operating normally, but you should probably take it back in to the repairer and get them to check it over if you're concerned. They should not have given it back to you if the power steer was not bled up properly, or at the very least should have advised you that it was not fully bled, but would come right after a couple of days.
Dec 03, 2008 | 2003 Honda Odyssey
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
