Question about Vtech Cordless Phone Battery for 2429, 2498, 9110, 9119, 9152, 1712, 20-2438, 2101, 2121, 2151
V-tech 2498 landline phone with cordless
For some reason the LED display pad is all garbled-with just black dots; I cannot read anything or program phone; I have tried different outlets to confirm not the electrical; other other phones light up etc and can be programmed but really want to use this particular phone. Can you please advise on how to fix this problem?
Suggestion
Posted on Apr 14, 2008
3 month old vtech suddenly stopped dialing out or recieving incoming calls. Numbers make beeping noises still and handset says "connecting" throughout. All lines were checked. Landline works fine.
Posted on Feb 03, 2008
  • 31 Answers
Tip 1 of 2 Recradle the handset for 15 seconds, then lift the handset and press PHONE. Tip 2 of 2 If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system: Step 1: Disconnect the power to the telephone base. Step 2: Disconnect the handset battery. Step 3: Wait a few minutes and then reconnect the power to the telephone base. Step 4: Reconnect the handset battery Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again. If that does not work, call the manufacture at 1-800-595-9511. Or take it back to where you purchased it and have then exchange it.
Posted on Jul 08, 2007
SOURCE:
My phones base and cordless have been plugged in since yesterday and I've checked all batteries and connections. Do I need to register with vetch before I can use the phones?
No - do you have the base connected to a landline? - Does the phone display show check tel line? I am assuming this is your typical home cordless phone. Is there power to all the handsets? If the screen is blank - you may have a bad battery. More information would help.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Lands Phones
Why is kx-tg4223 cordless phone system is garbled ?
Keep in mind that cordless phones are basically radio phones. You have a "station" that transmits the signal to the handset (receiver) This means you are subject to interference from other electric or electronic devices and can seem "sporadic."
Similarly, just like a radio or tv.. your phone has "channels" typically 2 or 3.
So first. Make sure your base is away from any other electronics to reduce interference. Then if "whomever" calls and you still have issues, try changing channels with the handset. (read your manual)
Jul 21, 2014 | Panasonic Lands Phones
I need to change the channel as it is interfering with my wifi. How do I change the channel?
While during a call, press the PROG/CHAN button in the middle of the bottom row of the handset keypad.
May 24, 2011 | Vtech VT 2498 Cordless Phone
How to set the clock on a 2429
Follow the instructions on page 5 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/390/UserManual/2326/t2429_manual.i1.pdf
Mar 01, 2011 | Vtech Cordless Phone Battery for 2429,...
I can call but when somebody calls me I cannot here anything
In any phone cordless // Mobile or landline there are two things one is microphone & other is speaker. Microphone is when u speak caller party can hear u & speaker is to hear when someone from otherside speak. In ur case the speaker might be faulty get it repaire by the local technician
Jul 09, 2010 | Radio Shack 433575 Cordless Phone
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
The display has gradually disappeard on all three handsets
that is an celphone? if celphone i think the problem is the LCD screen have the problem you can go to the service area and ansk to replace other LCD of your celphone that is the best way to do. you can not solve that even you change your battery or anything...
Jul 29, 2009 | GE 25952EE1 Cordless Phone
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Garbled color
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 15, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Lands Phones Logo
421 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
