Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Why does my upright freezer run constantly but it's not freezing anymore
    Sergeant:
    Champion:
  • 249 Answers
What you need is a new Compressor,w/o Electricals part number 5304475092
Posted on Jan 14, 2013
5 Suggested Answers
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
woodchuck789
  • 4066 Answers
SOURCE: Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 12, 2009
  • 173 Answers
SOURCE: frigidaire upright freezer MFU20F3GW7 (model)runs
Clean cooling coils....throughly. Check door seals.
Posted on Jul 08, 2009
SOURCE: I bought a used Kenmore upright freezer, it's been running all the time.
I'm Not a pro, but the comments refer to a refrigerator. I don't think they read your problem from start to finish. I went to RSI in Phoenix, and I would say it is low on refrigerant. I hope it's 134a.
Good Luck
Over the years the freon sloowly leaks out, it might need only an ounce or two but it will fix it in my opinion. I have the same problem with mine.
Posted on Jul 29, 2009
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Freezer does not freeze anymore
the freezer usually has the condensor coil sandwiched ilong the outer cabnet and in the back the lines come out in to the compressor compartment as a tech i have found the steel line rusts where the epoxy coating is no longer in tact so i would say you most likely have leaked out the refrigerant
Feb 10, 2013 | Freezers
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Our 2nd hand Kelvinator upright is running but does not seal the door with a vacuum and is not freezing food anymore
to solve this problem please change the rubber gasket of the door then check the freezing.
Aug 18, 2009 | Freezers
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
435 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
