Question about Vehicle Parts & Accessories
How do i program prestige PST 07SP remote start
4 Suggested Answers
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
reynosaelect
  • 165 Answers
SOURCE: how do i program the remote start function on prestige 997
email me i cant help you,i need to know the model of the alarm and what kind of vehicle is installed here is my email reynosaelectronics@live.com.mx
Posted on Mar 17, 2009
logosc75
  • 625 Answers
SOURCE: HAVE A PRESTIGE APS686T REMOTE
When you had the new keys programmed, the bypass was erased. More than likely, it was a key. Try this: put the first of the two new keys into the ignition, turn the ignition on. The theft light will light up, then go off. Immediately remove the key and put the second key into the ignition. Turn the ignition on, the theft light will come. When the theft goes out remote start the vehicle with the remote, quickly remove the key from the ignition. If the vehicle starts let it run for a few seconds and then shut the remote starter down with the brake. Wait a few seconds before testing the system.
If the above programming does not work the first time, try it again. It may take a few attempts because the process is time sensitive. You CANNOT allow too much time to pass between switching the keys.
Posted on Jun 09, 2011
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
HAVE A PRESTIGE APS686T REMOTE START ON A2003 FORD FOCUS.HAD 2 NEW KEYS PROGRAMMED. THE REMOTE START FLASHES MY THEFT LIGHT AND WILL NOT START. HOW DO I PROGRAMM THE PRESTIGE TO MY KEYS.
Jun 01, 2011 | Prestige APS686T Remote Start and Keyless...
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
Installed the prestige remote start(aps687n) on my 95 jeep grand cherokee but when i try to remote start my parking lights just flash 7 times and nothing happens. Any ideas???
Yes, the seven flashes mean that the tachometer setting has not been programmed. If you hooked up a tach wire (green with orange stripe) to an uncommon coil or injector wire, then you have to program tach: turn ignition on, press and release programming switch three (3) times. The parking lights will flash once to confirm. Turn ignition off. Press and hold programming switch. While holding the programming switch, start the vehicle. The parking lights will flash to confirm that the remote starter is getting a tach signal from the vehicle. Continue to hold the switch for approximately 15 seconds.The parking lights will continue to flash while holding the switch. Release the programming switch. The parking lights will come on solid for one second, then go off. The tach is not programmed. Turn ignition off. Test system.
Sep 19, 2010 | Prestige Remote Start
2002 Lincoln Towncar, Audiovox asp901, customer lost her keys and had new ones cut and reprogrammed. Now the remote start will not work. The pats light flashes and it wont start with the remote. I need to...
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Sep 15, 2010 | Audiovox APS901 Car Prestige Remote Start
Cant remember how to use the remote
To start the vehicle, press and release the Key/Trunk button two times within 2 seconds.
Jan 15, 2010 | Prestige Remote Start
How do i program the remote start function on prestige 997
Mar 13, 2009 | Prestige Remote Start
Dog Chewed my Prestige car starter
one purchasing the new remote audiovox will send you an instruction manual on the steps to programming the new transmitter. it is fairly easy, and they will give you the number to there tech department that if you have any trouble they will also walk you through it. hope this helps
Feb 24, 2009 | Prestige APS686T Remote Start and Keyless...
Prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Feb 15, 2009 | Prestige 2 Button Remote Security System...
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
