Question about Canon MF8100
How do I setup printing from my wifi to printer?
  • 2,878 Answers
Make sure Router and Printer are setup with DHCP. This will assign an IP to the printer. Once they are communicating, setup the printer on the computer with the IP address, and install printer drivers.
Posted on Jan 14, 2013
How do i setup my dell wireless printer?
Its very easy to setup dell printer by own.You just need to follow some simple steps.Steps are already explain with images you can check this How Do Set up Dell Wireless Printer Install Dell Wifi Printer Fixotip
Jan 03, 2018 | Dell Office Equipment & Supplies
Epson xp-605 switches off
Someone at SuperUser contacted Epson and was told to turn off the WiFi router (break connection), then disable Google Cloud Printing. That had mixed results.
Others found it easier to disable WiFi on the printer, then disable GCP.
Dec 06, 2016 | Epson Expression XP- 605 Inkjet...
MX340 connected to mac is offline despite drivers, cable and wifi assistant update. I have set this up before with the cd sent information to print. I see the printer in my printer queue but it says...
Try plugging it in directly.
Sometimes the wifi printer has to be set up AFTER the hardwire setup.
If you are desparate, plug it in directly to your computer to get your job done and figure out the wifi later.
Feb 11, 2013 | Office Equipment & Supplies
Unable to communicate thru WiFi to print
A solid green Wi-Fi light indicates that it is connected to a wireless network. An orange light indicates that it is not connected to a network.
Another way to determine if your printer is connected to your network is to print the wireless network setup page. From the printer operator panel, press the Setup button (wrench icon) > Network Setup > Print Setup Page. Your printer will then print the network settings. Check the SSID, signal strength, or trouble code.
A quick fix to this problem (especially if your printer was working fine before with your wireless network) can be achieved by resetting the printer and/or rebooting the PC.
Oct 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I think I accidently cleared my wireless wifi on my printer.... the wifi light is orange instead of green so not connecting
Try to print the network settings page to determine if your printer is still connected to your wireless network or not. On the printer operator panel, press the Setup button -> Network Setup -> Print Setup Page. Check the SSID if the printer is still registered to your wireless network. If not, you may need to reset your printer's wireless network adapter. Press Setup -> Network Setup -> Reset Network Adapter. The wifi light on your printer will then momentarily turn off. Once it turns on solid orange again, you may reconfigure your printer to connect to your wireless network.
If your printer is still registered to your wireless network, then it could be just a slight communication problem. Try to unplug and replug your printer into the power outlet to reset it. Doing this usually fixes minor communication issues.
May 03, 2011 | Lexmark X4690 Wireless InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
I have a WIFI and I heard that I can connect my HP OFFICEJET 5610 ALL IN ONE into wireless using my WIFI connection. Please assist me. Thanks a lot, Toha ****
hi tohafaniwang
the HP OFFICEJET 5610 doesn't have an internal wireless adaptor therefore you would not be able to connect it wirelessly to your wifi network. Although there is an option to get a wireless LAN routher/printserver wherein you would connect the printer to the wifi print server/router using the usb 2.0 cable. using this you would be able to setup that all that connects to your wifi network would be able to print to your printer.
Hope this helps
janc30
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
Canon mp620 not connecting to my wifi laptop
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Jul 29, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Computers & Internet Logo
123 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
