SOURCE: Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
SOURCE: Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
SOURCE: Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
SOURCE: burners sometimes will not light
You can check the ignitors/wiring by switching
the output wires at the spark module. If the
front ones work & back ones stop working, change
out the module. If no change take a look at the
ignitor(remove screw on bottom to remove
ignitor), ignitor wire & ground wire by removing
the burners.
Possible Causes Of Continuous Sparking:
Defective spark wires.
Continuous high heat can cause spark wires to
degrade. Use volt/ohm meter to determine
continuity
of spark wires. Look for obvious cuts/ abrasions
or pinch points. A defective wire can allow
spark voltage to transfer through insulation to
ground prior to reaching spark electrode. Under
normal circumstances all igniters fi re together
and if the burner in question has found an
easier
ground path the spark will go there. It will
not, however, in most cases have found a
CONTINUOUS
ground path such as what the fl ame would
provide under normal circumstances. This will
cause
the spark module to re-ignite.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
