Question about Sharp Mx-4501n mx4501n
How do you check the color cartridge usage on Sharp Mx4501n printer if there is no alert?
I have a Sharp MX4501N copier/printer and wish o determine how much of the toner cartridges have been used up.
  • Anonymous Mar 27, 2014
    set time
  • Sharp Expert
  • 337 Answers
Hold down the copy button. These are approximate values and are calculated so they are not right on.
Posted on Jan 30, 2013
JayBlair
  • 328 Answers
SOURCE: leaking toner
Make absolutely sure you are using new OEM Sharp supplies for this machine. I sell OEM and generic, and I always have trouble with generics leaking in Sharp copiers. Also if the drum unit has toner backed up in the waste channel, it will leak out.
Posted on Jul 31, 2007
keithd2704
  • 56 Answers
SOURCE: Dirty Background on Printouts
The most likely problem is not with the drum unit but rather with the developer unit and there is a leakage current within the unit causing the 'ghosting' on the printed images.
I would suggest that you replace the developer unit within the system. It is quite possible that the waste toner blade is contaminated with debris from using non-OEM toner within the unit. Therefore leaving residual toner particles on the surface of the drum.
Try this solution and see if that corrects your problem. This solution can be applied to virtually any laser printer, copier or MFP device in the industry. The problem is nearly 99% of the time related to CHEAP toner cartridges that are refilled or refurbished and the company doing the work does NOT replace the cleaning blades within the units, and they use a generic polyester-resin toner that does not conform to manufacturer standards.
I worked as a Design Engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times in the industry. The price you save on using recycled cartridges ends up costing you more when you have to replace a developer or drum unit.
Hope this information helps you out.
Cheers,
Keith
Posted on Oct 23, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 118 Answers
SOURCE: Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Posted on Aug 31, 2009
Sharp Mx4501N. What does error F2 66 mean?
There is a problem with the Magenta toner.
May 05, 2015 | Sharp Office Equipment & Supplies
Sharp mx4501n no display
replace panel unit first and then if problem persist replace MCU
Feb 20, 2014 | Sharp MX-3501N All-In-One Printer
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
F2-65 shows on my sharp mx4501n copier what will i do
Your machine is starved for cyan toner. Either the toner supply pipe is blocked or the CRUM counting chip on the back of the cyan toner cartridge has zapped out or wound down to zero. Try replacing your toner cartridge. If still no go you'll have to take out the drums, developer tanks and transfer belt, hold a piece of paper under the cyan supply pipe spout and tap the pipe to break up the toner.
Jun 08, 2013 | Office Equipment & Supplies
What can be the cause of colour unit not rolling on mx4501n sharp copier
Please specify whether you are talking about drums, transfer, developer, or that the color Start button does not light up.
Jun 04, 2013 | Office Equipment & Supplies
How can I check drum and developer usage level for Sharp MX 2300?
You can press #*C* respectively, then press 22 start 1 start respectively then it will show you all the counteres including drum and developer for the 4 colors.Rate this and vote for this
May 17, 2011 | Sharp MX-2300N Color Copier
What does an error code H4-01 mean on a Sharp MX4501N copier? The machine no longer copies, simply displays: Call for service Code H4-01.
Fuser Heater failure. The fuser is the part of your machine that heats up and "fuses" the toner onto the paper. It is located right near where the paper exits the copier. This error code means that the fusing unit is not heating up as it should. The most common failures in order of ocurance are thermal fuse, thermister and heater lamp. In any case you are going to need a service person to come out and diagnoe which part has failed, replace the part and reset the code for you. Should not be more than say $200 to repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 13, 2010 | Sharp Copier Cabinet Printer
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Service code H2-01
Press "#" "Interrupt" "Clear" "Interrupt" then hit "14" "Start" then go to sub code "0" or it may ask to clear code.... Good Luck..
May 13, 2008 | Sharp AR-M237 Digital Copier
Sharp Mx-4501n mx4501n Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
