Question about Toshiba CZ32V51 32" TV
Sound but no picture
The other night, the picture finally quit. There is sound but no picture. Replaced fuse F301. Still no picture. When the TV is tapped...either by the FBT or on a heat sink, get an intermittent white line across the screen for a fraction of a second. Resoldered FBT. Any ideas? Thanks.
  • Anonymous Mar 17, 2014
    2 to 3 seconds good picture, after few seconds the picture has a distorted lines like arking fbt. i already areplace the crystal 503 & fbt still nothing changed. what is the problem of the tv? sharrp 20v-s100
  • 398 Answers
A white like across the screen means that the vertical circuit has stopped working. Look for a small fuse that looks like a resistor near the vertical output IC, replace that fuse if open and resolder the pins on the vertical output IC.
Posted on Jul 08, 2007
SOURCE:
Samsung un60eh6050fxza tv has sound, light in background, cannot see any menu picture when menu is selected, no picture. what board do I need or is it some thing else?
Hi John,
The board that might need replacing is the T-con board but before replacing it, I would suggest to measure the voltage at F301 on the T-con board.
Replacement parts can be found by checking the link provided below:
Search results for un60eh6050fxza
Mar 26, 2018 | Samsung Televison & Video
Loud pop
Check the lamp.
Pull it out and look at it.
More than likely the lamp has shattered inside the set and needs replaced.
Bulb replacement is made for consumers and can easily be replaced.
Need any more information, respond to this post and I will reply.
Dec 30, 2007 | Panasonic PT-45LC12 45" Rear Projection...
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have sound but no picture. Turned TV off last night and when I turned the TV on this morning there was good sound on all channels, but there is no picture. Just a black screen
is hv circuit problem a power transistor to 25KV transformer maybe dead, check the HV Circuit, or 1XXV output from Mains transformer the fuse maybe dead
Mar 11, 2010 | Sony KV-36XBR450 36" TV
TV Toshiba CF32G50
I think you have a vertical problem. Turn up screen voltage to see if there is a tin horizontal line across screen. If so replace vertical output IC and the 100uf/35v capacitor in the vertical circuit.
Oct 31, 2008 | Toshiba CF32G50 32" TV
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
RCA 32f530t 32 inch tv
This has happened to me quite frequently. I have replaced the fuse at least 8 times. You just take off the back of the t.v. and on the bottom you will see a small glass fuse. just pop it out and go to radio shack and get a pack of replacements. about 4 for 3 dollars.
Jul 09, 2008 | RCA 32F530T 32" TV
Sony CRT Tv (KV-T29SZ8)
When you see white lines at the top of the screen, it means that the pump-up capacitor next to the vertical output IC is bad and the IC is about to quit. When the output finally quits, you get a black screen with possible dim spots. The vertical output IC and its pump-up cap will have to be replaced, and the little fuse resistors next to the flyback in the + and - supplies to the vertical output IC must be checked too. If you have experience working on TV's then you can do it yourself, but if not then have the set serviced by a tech experienced in Sony sets.
Aug 09, 2007 | Sony KV-35S42 35" TV
Toshiba CZ32V51 32" TV Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
