Question about Kitchen Ranges
I have a magic chef furnace model #acd13-u60-4, 60,000 btu. When i turn on the furnace from the thermostat the unit lights up and the sound of the ignitor clicks for about 25 seconds while there is already a little flame and then the furnace ignites then shuts back down to a low flame and continues to do the same steps then finally kicks in for a while. Sometimes when it finally kicks on i hear a boom and it opens the doors where the unit is located. I do smell gas sometimes for a little while so this is telling me that there is gas buildup at times. Need some help or suggestions.
  • JONNY LANG Jan 14, 2013
    Sorry I'm new to this site. This isn't a kitchen range. It's a furnace from a split system residential unit.
fridgetech
  • 473 Answers
SOURCE: Gas range (oven)won't lite (gas broiler works fine)
Sounds like an ignitor problem or possibly a dirty orifice. Model #'s are usually on the frame behind the bottom drawer.
Posted on Oct 05, 2007
jumptrout51
  • 3361 Answers
SOURCE: Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Posted on Apr 23, 2009
  • 68 Answers
SOURCE: Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
Posted on May 18, 2009
e-Guru
  • 3917 Answers
SOURCE: Magic Chef Range in camp trailer, pilot light in
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Posted on Jun 14, 2009
protek480
  • 1714 Answers
SOURCE: burners sometimes will not light
You can check the ignitors/wiring by switching
the output wires at the spark module. If the
front ones work & back ones stop working, change
out the module. If no change take a look at the
ignitor(remove screw on bottom to remove
ignitor), ignitor wire & ground wire by removing
the burners.
Possible Causes Of Continuous Sparking:
Defective spark wires.
Continuous high heat can cause spark wires to
degrade. Use volt/ohm meter to determine
continuity
of spark wires. Look for obvious cuts/ abrasions
or pinch points. A defective wire can allow
spark voltage to transfer through insulation to
ground prior to reaching spark electrode. Under
normal circumstances all igniters fi re together
and if the burner in question has found an
easier
ground path the spark will go there. It will
not, however, in most cases have found a
CONTINUOUS
ground path such as what the fl ame would
provide under normal circumstances. This will
cause
the spark module to re-ignite.
Posted on Sep 01, 2009
I have a magic chef furnace, armstrong series if the pilot light and ignightor both work but the burners wont light is it possible the thermocuppler bad?
The thermocouple keeps the pilot light on. If the flame blows out it shuts off the gas to the pilot lite only the board that has the igniter on it supplies power to open the main burner as long as the igniter is operating. Sounds like the gas valve is nor working.
Nov 19, 2014 | Magic Chef Refrigerators
Magic Chef HMCF7WI is the green light suppose to go off ?
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
Magic Chef #HMCF7W1 should the green light go off?
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
Furnace blower won't turn on
You may need to replace the sail switch. It senses the fan speed and when it connects the gas valve should open and furnace should fire up.
Dec 09, 2013 | SUBURBAN MANUFACTURING Rv Motorhome...
Suburban rv furnace.
The best thing to do for these units is replace the ignition module, on Ebay they are cheap usually. Clean all orifices where any pressure switches or tubing connects on the induced drafts assembly, Does the pilot ever light?
How do i wire the thermostat to the magic chef furnace
Inside the furnace there is either a transformer relay with the markings of R & W stamped near the terminals or T TH or a circuit board with terminals marked R and W. This is where your thermostat wires will connect to. At the thermostat, connect the R terminal to the wire connected to the R terminal at the furnace or T terminal at furnace. The other wire goes to the W terminal on the thermostat. This will give you heat
Jan 16, 2011 | Heating & Cooling
I have 210k btu Magic Chef gas fired furnace and I need a model #
Replace the start capacitor. Take an amp draw on the motor when it starts. Compare that with the rating plate for FLA.
Nov 04, 2009 | Continental Heating & Cooling
I have an old Magic chef furnace and need to replace the Fan Motor were can I find the fan spec for replacement? It was built in 1987 Model # G8A75DC10-17 Serial# A 10221CKA Forced Air Furnace Categorie I
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Oct 06, 2009 | Heating & Cooling
Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Feb 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
