Question about JVC Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
  • JVC Master
  • 5,190 Answers
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Posted on Jan 14, 2013
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
  • 5 Answers
SOURCE: KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Posted on Sep 18, 2008
  • 133 Answers
SOURCE: tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
STYLUSCITY
  • 271 Answers
SOURCE: I have a Denon DP-51F turntable. It was fine the
Hi, it has seized from lack of use. Disassemble and lube it. styluscity@gmail.com
Posted on Sep 13, 2010
Grubhead
  • 5190 Answers
SOURCE: My tone arm has suddenly
Generally the cause is one of 3 things. 1 Damage to the stylus or dirt. 2 Lack of pressure to the stylus. 3 Anti-skate control set to low.
First check the stylus you should feel it sticking in you finger a bit. 2 Has the weight on the end of the arm become lose? Adjust for the correct tracking weight of the cartridge. 3 Check the manual for what the anti-skate control should be set to.
Posted on Feb 24, 2011
Turntable arm not moving across record?
Try, without any record on the table, if you can move the are, to the centre of the table. If you feel anything that is holding the arm, try to find out what it could be. Never use force. Also look inside if you can't find a clear obstruction on the top of the table. If you should find anything, don't bent, or don't break anything. Let a technical skilled person look why the obstruction is there and where the "thing" should be so the aren can move free. Perhaps you ned the obstruction for something only a few centimetres to the left or the right.
Jun 26, 2014 | JVC Audio Players & Recorders
I have a JVC turntable and an old Sansui reciever. Last night I was playing a record, and it stopped playing out of one speaker, and makes a loud buzzing noise. However, when I push the Mono button
You should check the connections to the turntable, it sounds like it might be feedback hum, caused by a wire touching or something like that. Don't forget to check the connections to the cartridge too.
Feb 09, 2014 | Audio Players & Recorders
The record plays but it is really quiet, how do i turn up the volume?
You should check that it is plugged into a socket in your amp that is designed for record decks. If the amp does not have a dedicated socket, then you need to get a magnetic cartridge pre-amp. The record deck plugs into that and that goes into your amp. That will make the deck as loud as the other sources, such as CD players etc.
Jun 24, 2013 | JVC AL A158BK Turntable
I have a garrard turntable and I'm trying to hook
Connect the turntable wires into the recievers phono input and you should be good to go
May 16, 2011 | Technics SA-EX110 Receiver
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
Arm doesn't appear to make contact with record
arm lift mechanism not dropping full extent
Apr 11, 2009 | Audio Players & Recorders
295 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
