Question about Sony Cyber-shot DSC-W120 Digital Camera
Turn power off again sony dsc w120 shot - Sony Cyber-shot DSC-W120 Digital Camera
Disculpe tengo una camara sony DSC-W120 la bateria esta cargada y la quiero encender y no prende que puedo hacer saluda atte rodolfo
Posted on Jun 18, 2013
  • 74 Answers
SOURCE: sony cyber-shot dsc-w70
try gently pulling and twisting the end of the lense very gently dont do it till it pops but this should solve your problem
Posted on Aug 12, 2008
  • 74 Answers
SOURCE: Sony Cyber -Shot
try gently pulling and twisting the end of the lense and i mean gentle dont pull till it pops than switch it off and on again and you problem should be solved
  • 70 Answers
SOURCE: turn the power off and on again problem
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Posted on Mar 23, 2009
  • 586 Answers
SOURCE: SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Posted on Jun 14, 2009
  • 4090 Answers
SOURCE: Turn the power off and on again my sony digital
This is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal approach
Posted on Jul 26, 2009
How can I disable the power save mode of the Sony Cyber-shot DSC-W120 Digital Camera?
Hello hocak,
You can do that by:
Press Menu
Go down to the "Toolbox" icon and press center [ok] button
Then go down again to Settings (Wrench and Hammer icon) and press ok button
Choose POWER SAVE and then select OFF.
I hope this helped you.
You can rate my answer and may leave a testimonial if you appreciate my help.
Thanks!
Oct 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I cant get my camera to turn on. thanks for your
Fist charger your SONY Cyber-shot DSC-W120 battery and clean the connect place of the battery and camera. Please make sure that the battery has been charged by the Sony Cyber-shot DSC-W120 charger. Li-ion batteries life is about 2-3 years, and if you have stored your battery with no power for a long time, the battery maybe has been damaged. When store Li-ion batteries you should charged it at about 40% first.
May 06, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony cybershot dsc-w120 lens goes crazy whenever I turn it on and tells me to turn it off.
The camera should go off automatically when faulty. attempt to explore teh functions on the camera is discover the unique experience beyond power shut down requests. When powered on, capture a snap shot immediately or else the camera takes charge to poweroff to save batteries. Also, attempt to power charge since the insufficeient battery does not allow the camera to stay on long.
Jan 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony camera wont take pictures
It is problem of lens mechanism that does not send initialize signal to system control chip and camera tries 3 times for that then give up so that error message comes in result.
Replace lens assembly to fix the problem.
Local camera repair shop will help you to replace it.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot w120 digital camera won't pop lense out
Your zoomunit is defective. Rotronica has replacements for this camera.
Or contact your Sony repaircenter.
Regards,
Rob NL
Apr 06, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Turn the power off and on again problem
Mar 21, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
