Question about Exercise & Fitness
Flexstep cushioning cs1800s not working
When power is turn on.the console light up and turn off in a second.
    Top Expert:
  • 12,223 Answers
Titght any connector very well and clean it
2) replace the old batteries by new ones with the same mark
3) tight the ribbon cables inside for keypads and cleant
4) adjust the REED switch clean it,test for open and faulty and tight very wel the connector ,see the diagram attached.
God bless you  flexstep cushioning cs1800s not working - 1_14_2013_9_50_59_pm.gif
Posted on Jan 14, 2013
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Jun 07, 2012 | Sony Playstation 3 (PS3) Console
How do you replace drive indecator light
1. Lift the little carpet in the console rear to the automatic gear shift. Pry with a small flat screwdriver will do the job.2. Remove the three Philips head screws.3. Remove one Philips head screws on each side of the rear console, they are located at the bottom front of the rear console panel. You may have to move the driver and passenger seat back to see the screws.4. Grab the back of the rear console and gently wiggle, pull backward and lift upward. Pull the hand brake so it is easier to remove the loosened rear console panel. 5. Use a flat head screwdriver to pry the rectangular 'cushion' around the automatic gear shift. Gently pry at various spot and the rectangular 'cushion' will come off easily.6. Now you are just one more plastic cover away from the burned bulb. The plastic cover that has those 'P'ark, 'R'everse, 'D'rive letters is held in place by four snap on latches. Use a small flat head screwdriver and gently push the black latches inward in a downward motion, once the screwdriver head gets inside the grey latch holder it will free the black latch. Work on each of the four latches in turn.7. Wiggle the plastic cover until it is completely loosened from the four latches. Gently lift the plastic cover up. The automatic gear shift will stop the plastic from being lifted out completely. You still have enough room to work with. You will see the little burned bulb directly below those 'P'ark, 'R'everse, 'D'rive letters. Gently pull the bulb out. I got my replacement bulb at Canadian Tire, Motomaster instrument replacement bulb 194LL (clear, long lasting, 2 bulbs for $2.99Cdn). It is a push-on bulb.8. Test the bulb by starting your car and dash lights.9. Snap back the plastic 'P'ark, 'D'rive cover. Put back the rear console panel and finally the rectangular 'cushion' around the automatic gear shift.
Dec 17, 2011 | 2006 Toyota Corolla
WII DOES NOT TURN ON AT THE POWER BUTTON
remove the power cord from the wii. hold the power button in for 15 seconds.
plug the power back in. if the power light comes on check the color.
green is on, yellow is standby and red is totally off.
if there is a light press the power button and see if it turns on. if it does not then from a Wiimote, press and hold the power button on the remote. this should turn the console on. if the console does not turn on and the remote batteries are good you can try one more thing IF the light is on.
press and hold the reset button for 10 seconds on the system. disconnect power and replug. if you still cannot turn it on then your system is bricked or damaged and needs replacement.
in any case the power button is broken you can turn the console on and off from any remote
Aug 24, 2011 | Nintendo Wii Console
Yellow light on wii
It's just the way the wii works. Hold the power button for about 5 seconds and the power button will go red and turn off instead of going yellow and going into standby mode.
www.wiihdmods.com
May 07, 2010 | Nintendo Wii Console
Have it hooked up to the hdmi and it wont work at all
Put your PS3 in standby mode (hold the power button until the light turns red) then release, and hold the power button again for about 10 seconds, or until the light beeps a second time. When the PS3 restarts, it should display on your HDMI.
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
I can not connect my wireless controllers. My
hi, i had this problem and it is really annoying, but is a really easy fix, first you must turn on your console leave the controller off, hold the sync button on the console for 30 seconds then turn the console off, remove all the wires from the console and the power plug from the wall, after about 5 minutes, reconnect the wires and turn the console on then the controller, now try and sync them, if this hasnt worked im sorry try calling microsoft im sure they can help. www.xbox.com/support
Jul 10, 2009 | Microsoft Xbox 360 Console
One red light on my 360
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
May 20, 2009 | Microsoft Xbox 360 Elite Console - Black
Ps3 not turning on
The only thing i can think of is click the switch to turn off the PS3 completely leave it off for about 30 second turn the switch back on and try again. If the doesn't work you may have a problem with your power supply and might need to get your PS3 serviced
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Exercise & Fitness Logo
16 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
