Question about Exercise & Fitness
How do you calibrate a bladez t-5.9 treadmill
    Top Expert:
  • 12,223 Answers
Follow the steps and proceed according. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Posted on Jan 14, 2013
  • reg dougan Jan 15, 2013
    I wish I could say that your expertise fixed this but that is not the case. This unit has the year 2007 so is there an older calibration magic trick for an older unit. Please help me out and thankyou in advance
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
Posted on Dec 31, 2012
Testimonial: "WHERE DO I FIND YOUR PERSONAL TIPS FOR TESTING THE MOTOR,,,, THE DRIVE MOTOR WORKS FOR ABOUT 2 TO 3 SECONDS THEN SHUTSDOWN UNDER A E6 CODE, I SUSPECT THE ELEVATION MOTOR OR SETTINGS IS OFF"
I need to reset bladez t5.9 treadmill and calibrate
reset with the button to the side from main motor
God bless you
Jan 14, 2013 | Bladez Fitness Exercise & Fitness
Factory settings for bladez t 5.9
go to the reset the machine for the MENU, and adjust default factory .
God bless you
Jan 14, 2013 | Bladez Exercise & Fitness
No power to console on bremshey scout treadmill
Replace 12a 250v ceramic slow blow fuse 5 X 20 mm on power board.
Jan 10, 2013 | Bladez Exercise & Fitness
Dec 31, 2012 | Bladez Exercise & Fitness
My Ion treadmill with LCD screen has an error message
1) adjust the speed sensor, clean it, tight the connector or plugs.see the diagram
2) adjust the Reed switch, clean it, and tight the plug or connector.
tight the ribbon cable inside.se the diagram
3) try to RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 19, 2012 | Bladez Ion 9.9 Fold-up Treadmill
Err 2 keeps bleeping
adjust the speed sensor, see the diagram attached , clean, and tight the connector very well.
2)Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) Run the software calibration for diagnose, troubleshooting.
sincerely. God bless you
Apr 18, 2012 | Bladez Fitness BH T8 PRO Treadmill...
Whats up with the P350 Treadmill? Bladez Fitness is advertising it as a $1499.99 unit for $499.99 at Academy. Why can't I find any information on this unit.
BH Fitness
P350 Treadmill
hi this is the best i can find, also make sure they give a full gurantee, these treadmills are not that good, if your looking for something more better try a weslo candence m6 new from 400
r20" x 50" Running Belt
  • Folds up for Space Saving
  • Safe Drop Lowering Feature
  • Large Blue Backlit LCD w/ Dot Matrix Allow More Information at the Same Time
  • 2.25 Continuous HP Drive Motor
  • 9 Built in Programs
  • Quick Speed and Incline Keys
  • Personal Cooling Fan
  • Contact Heart Rate Sensors
  • 325 Pound Max User Weight Capacity
  • 10 Mph & 13% Grade
Nov 21, 2010 | Bladez Exercise & Fitness
Where is the speed sensor connection for a blade z
their is two place any of the treadmill either on the frame by the front roller/ pulley or on the motor itself by the fly wheel or the opposite end.
May 13, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Exercise & Fitness Logo
67 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
