Question about Bladez Fitness Exercise & Fitness
I need to reset bladez t5.9 treadmill and calibrate
    Top Expert:
  • Bladez Fitness Master
  • 12,223 Answers
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
reset with the button to the side from main motor
God bless you
Posted on Jan 14, 2013
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: auto calibration instructions for merit 725Tplus
see this instruction and fix it. God bless you
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Posted on Dec 15, 2012
ercupa190
  • 12223 Answers
SOURCE: need to calibrate my treadmill manually, not sure how to do it
follow the instruction and fix it. God bless you
ercupa190
  • 12223 Answers
SOURCE: F6 CODE ON A BLADEZ TREADMILL
please test the motor see my personal TIPS for motor help. However this is indication, controller failure. see the block diagram too.ipqidqpmpqaaaabjru5erkjggg==12_31_2012_3_35_30_pm.gif12_31_2012_3_36_25_pm.jpg
Posted on Dec 31, 2012
Testimonial: "WHERE DO I FIND YOUR PERSONAL TIPS FOR TESTING THE MOTOR,,,, THE DRIVE MOTOR WORKS FOR ABOUT 2 TO 3 SECONDS THEN SHUTSDOWN UNDER A E6 CODE, I SUSPECT THE ELEVATION MOTOR OR SETTINGS IS OFF"
Looking for owners manual for Bladez bf-6527hrp treadmill
Try Googling (bladez)(bf-6527hrp)(manual) without parens.
Jan 22, 2018 | Bladez Exercise & Fitness
Vibelife Vibration platform turns on at full speed and shows error. None of the buttons stop it I have to cut the power
yes there are reset switch to the side to the main button stop. However you must RUN the software calibration for easy diagnostic and fix it. Opent the keypads and clean the diryt switch, with contacts cleaner from dirty, oxide, corrosion, and try again.
Nov 26, 2013 | Bladez Fitness ABP Vibration Platform
How do you calibrate a bladez t-5.9 treadmill
follow the steps and proceed according. God bless you
Jan 14, 2013 | Exercise & Fitness
Factory settings for bladez t 5.9
go to the reset the machine for the MENU, and adjust default factory .
God bless you
Jan 14, 2013 | Bladez Exercise & Fitness
Dec 31, 2012 | Bladez Exercise & Fitness
My Ion treadmill with LCD screen has an error message
1) adjust the speed sensor, clean it, tight the connector or plugs.see the diagram
2) adjust the Reed switch, clean it, and tight the plug or connector.
tight the ribbon cable inside.se the diagram
3) try to RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 19, 2012 | Bladez Ion 9.9 Fold-up Treadmill
Err 2 keeps bleeping
adjust the speed sensor, see the diagram attached , clean, and tight the connector very well.
2)Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) Run the software calibration for diagnose, troubleshooting.
sincerely. God bless you
Apr 18, 2012 | Bladez Fitness BH T8 PRO Treadmill...
Whats up with the P350 Treadmill? Bladez Fitness is advertising it as a $1499.99 unit for $499.99 at Academy. Why can't I find any information on this unit.
BH Fitness
P350 Treadmill
hi this is the best i can find, also make sure they give a full gurantee, these treadmills are not that good, if your looking for something more better try a weslo candence m6 new from 400
r20" x 50" Running Belt
  • Folds up for Space Saving
  • Safe Drop Lowering Feature
  • Large Blue Backlit LCD w/ Dot Matrix Allow More Information at the Same Time
  • 2.25 Continuous HP Drive Motor
  • 9 Built in Programs
  • Quick Speed and Incline Keys
  • Personal Cooling Fan
  • Contact Heart Rate Sensors
  • 325 Pound Max User Weight Capacity
  • 10 Mph & 13% Grade
Nov 21, 2010 | Bladez Exercise & Fitness
Exercise & Fitness Logo
Top Bladez Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Bladez Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
