Question about Drills
5370-1 milwaukee hammer drill just stopped running
rowdy45176
  • 2176 Answers
SOURCE: broken shaft 3/8 milwaukee hammer drill mod #5392-1
Yes it does. The collar mechanism and retaining ring come off and under all that is a sleeve with steel ball bearings, what I am saying is it would be better to take to a repair shop. I worked on this tool for years and they are decent to use, but repairing that without proper equiptment is not fun. Let me know your area and I will try and find a repair center for you.
Posted on Mar 15, 2009
  • 104 Answers
SOURCE: stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
Posted on May 23, 2009
  • 583 Answers
SOURCE: When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
Posted on Aug 15, 2009
  • 548 Answers
SOURCE: when hammer drilling after drilling a few holes it
check the trigger switch inside the gun , a few small screws in the casing will have to be unscrewed then take the gun in half and check the trigger switch connections and possibly replace the switch I have had this problem before with no obvious signs of wear or un connected connections but then i replaced the trigger switch and it worked fine
Posted on Aug 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: Milwaukee heavy duty hammer drill only works when
could be loose connection at the switch or brush holders. You can go to Milwaukeetools.com to download a breakdown for this tool.
Posted on Aug 15, 2010
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
Milwaukee 5370 armature removal
probably need to remove the brushes from the other end as the rear bearing is bigger than the commutator section and the brushes fall in to the section and hit the bearing preventing what you want to do
Sep 06, 2016 | Milwaukee Electric Tool 5370 - 6 1/2"...
How to replace brushes in this hammer drill
One big black plastic screw on top, one on the bottom. Unscrew them - they're brush holders. Inside are the brushes. Pull them out.
Aug 07, 2014 | Milwaukee Electric Tool 5370 - 6 1/2"...
Milwaukee Magnum Hammer Drill
If the chuck is completely jammed, you can replace it. If its locked but open, then you can remove the screw holding the chuck with an allen wrench. It's going be be tough because it will be secured with glue, such as loc-tite, and it will also be a left handed screw. So be sure to turn clockwise to unscrew it.
You can buy the part at this website, or at a milwaukee service center:
http://www.ereplacementparts.com/12-chuck-p-140621.html
It's a little pricey, but better than buying a new drill. You should also be able to have a service center put the part on for you, if you don't feel comfortable taking it apart.
Feb 03, 2013 | Milwaukee Electric Tool 5370 - 6 1/2"...
I have a Milwaukee Hammer drill #5370-1, serial #672D 5044 60047. The drill stopped working and I suspected worn brushes. Now that I have taken it apart and found the brushes were not worn (and I found...
The brushes are usually replaceable from outside the drill. Make sure each spring is properly tensioned. Make sure the electrical outlet is live by trying a working lamp or other item. Pull the trigger full on and wiggle the cord where it goes into the plug--if the tool turns on intermittently, suspect a bad cord connection at the plug. Just replace the plug after cutting the cord back an inch or so. You can test the speed control by a temporary jumper across the module which should allow the tool to run full speed. Make sure the reversing switch is ok. Hope this helps!
Jan 06, 2011 | Garden
Milwaukee heavy duty hammer drill only works when pointed upwards. As soon as I point it down the motor stops (or doesn't start with the drill in that position).
Aug 14, 2010 | Milwaukee Drills
Variable speed doesn't work on Milwaukee Magnum hammer drill
how new is the tool. Give me the serial number and I will come up with a solution, also what is the switch number you bought. Let me know.
Dec 31, 2009 | Milwaukee Drills
When hammer drilling after drilling a few holes it stops then starts then stops then starts etc.#5370-1 magnum .i don't believe it is the cord
Aug 21, 2009 | Milwaukee Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Drills Logo
61 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
