Question about BenQ MP511 Projector
Dust particles being projected onto screen with BENQ MP 525 projector
I have thousands of dust particles showing up now on my screen. We took the projector BENQ MP525 apart and blew air thro ( high pressure) and it did nothing. It appears the lenses can NOT come apart...help.
    Champion:
  • 220 Answers
White spots on the screen are generally caused by a bad DMD chip.Multiple elements of the chip remain continuously on causing these spots.Solution is replacement of DMD chip.
Samr
Posted on Jan 29, 2013
3 Suggested Answers
heathgr
  • 442 Answers
SOURCE: hi i have multiple black/white spots
It sounds like the DMD chip has faulty pixels, some permanently on some off
Posted on Apr 11, 2011
  • 75 Answers
SOURCE: Benq MP 721 projector purple colour when it projects.
You are missing one of your primary colors and this is usually to a faulty pin where you are connecting your vga cable to. It could be either the pin on vga port of your projector or it could be the vga cable itself. Please look at the pins especially if you are using one cable to try with all the compputer.
Posted on Jun 05, 2010
Hi My mp 575 is not even 6 months old and yet it is showing hundreds if not thousands of scatered black pixels that look like dust and bright pixels that look like stars in the sky. I searched the...
hi,
You projector have problem with DLP engine. You have to replase the DLP and its driving module. If it have warrenty then conatct nearest Benq authorised servicing center. Because the DLP engine will cost a lot, and also the avilabilty of the same is very rare
OK
Aug 17, 2011 | BenQ MP575 XGA 3000 ANSI 26001 23KG...
How can I connect BENQ MP510 multimedia projector with Acer Aspire one D255E notebook using windows 7? Do I need installation of extra driver for that?
Hi!
No you don't need a driver, connect it using a VGA Cable, then press FN Key at the same time with Fkeys that has a monitor screen Icon on your keyboard.
Hope this helps.
Mar 17, 2011 | BenQ MP510 DLP Projector
Jun 02, 2010 | BenQ MP721 DLP Projector
How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
Hi there my benq dlp projector is showing white spots on the screen when the screen is black can you help me?
This is caused by dust on the lens assembly. If you can remove the lens, clean the surfaces with a lens cloth. That should resolve the problem. It is possible that the there is dust in the optical pathway inside the unit as well. If the cleaning of the lens does not resolve the problem, the unit should be brought in for a professional cleaning. It is not suggested that anyone open up these units as there are fine adjustments that can be changed internally easily that could result in convergence problems.
Dan
Jan 29, 2010 | BenQ PB6100 Multimedia Projector
Our picture is yellow
first check the cable. second, go into the menu and reset the settings to factory default. this will reset any image changes and the resolutions. third, clean it out. dust collecting on the colorwheel will cause this, too. if you still have a problem and you just bought it, it should still be under warranty, so send it in to get repaired for free.
Sep 02, 2009 | BenQ MP610 Multimedia Projector
Benq 6110 - mounting projector onto ceiling
You need to navigate to the 'advance' menu and under the 'mirror' setting select 'ceiling front' or 'ceiling rear' depending on whether you are front or rear projecting. It should all be on page 29 of the manual.
Hope this helps
Matt.
Apr 01, 2008 | BenQ PB6110 Multimedia Projector
My projector Benq pb6200 needs cleaning from the inside how???
I have an Optoma EzPro 737 DLP projector that accumulated dust inside the lens and for ages I couldn't figure out how to get rid of it. It cast shadows onto the picture and scattered light outside the edges of the picture. I thought I'd have to dismantle the whole lens assembly (then realised that this is virtually impossible without being an expert). I then stumbled upon a little black rubbery plastic panel on the side of the light path, which unclips. I then realised that the dust had built up on the lens that sits in front of the DMD chip (the thing that makes the picture).
Here's what I did, with the case open and having vaccuumed out all the dusty parts of the projector to avoid making the situation worse:
- Took off the little rubbery panel,
- Removed the lamp from the projector and placed a flashlight inside, shining into the light path (or a mirror directing light from a table lamp above)
- Looking directly into the lens from close up, you should be able to see the particles of dust stuck to the inner lens (with a nice magnified view)
- First tried blowing air into the gap on the side of the light path (I used a balloon pump).
- Next, I poked a piece of thick nylon fishing line into the hole so that it could touch the surface of the inner lens.
- While looking into the lens, I could see the tip of the nylon, then directed it to the largest dust particles and used it to scrape them off (nylon is much softer than glass, so won't scratch the lens).
- This was quite time consuming but I got rid of the most obvious bits.
I'm not sure how different this would be for another model of projector - but I hope it helps!
Dec 16, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ MP511 Projector Logo
456 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
