Question about Cell Phones
Samsung galaxy s2 not charging
Phone is 1 year old. All of a sudden I can't charge either by plug-in charger, computer usb charger or in-car charger. When I plug in it says charging but doesn't do anything or says "plug in your charger"
    Problem Solver:
  • 8 Answers
Either your battery needs to be replaced or charging port is damaged
Posted on Jan 14, 2013
4 Suggested Answers
  • 63 Answers
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
Posted on Apr 06, 2012
mohankumar63
  • 223 Answers
SOURCE: my phone (Samsung i8000) doesn't
Just follow this step.
* Your mobile charging socket as some problem.
* You just need to visit you are nearest Samsung service center.
* There they will fix you are problem in few minutes.
* After getting repaired check weather your mobile is charging correctly.
* Then your mobile will be just fine.
If you are satisfied with my answer then rate me.Thanks for your question.
Posted on Jun 24, 2011
  • 11 Answers
SOURCE: My samsung galaxy nexus doesn't always charge when
please book your complaint to service center
Posted on Apr 28, 2012
How do i get my phone to charge its been on the charger all day and i have a new battery i have a samsung galaxy 2
have you tried using a different charger? Try plugging it into the USB slot of a computer, does it charge then?
Feb 06, 2015 | Samsung Galaxy S2 S II i9100 16GB -...
Samsung galaxy s2 will not charge
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
http://www.youtube.com/watch?v=q4e-5xkhvHA
Jul 22, 2014 | Samsung Galaxy S Ii 2 Sgh-t989 16gb...
Samsung Galaxy S2 S95G will not charge
Usually this lack of charging is a faulty mini usb connector inside the SII phone or maybe the mini USB plug on the end of charger cable. If you have a friend with a working SII use their phone to verify your battery or try their good battery in your phone. This will confirm it' s a charging / battery issue.
Not sure if you did this:A workaround for a faulty mini USB conn. in the SII would to be to buy a new battery and an external battery charger with battery holder stand. Charge batteries in the stand and change the charged batteries over into the Galaxy SII as needed.
Jan 03, 2014 | Samsung Galaxy Cell Phones
My galaxy isn't charging
have you tried with a different charger?
had the same problem with my old one, solved it with a new charger...
Aug 28, 2013 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
My Samsung galaxy prevail suddenly reads and wont accept a charge. Im using the original "samsung" home charger. A small yellow triangle with a smaller image of a battery crossed out and appears within...
I would check the connection to the phone make sure it was not damaged and I would try a different outlet or a new charger before having to send your phone back ...
Jun 13, 2013 | Samsung Galaxy Prevail for Boost Mobile...
Samsung galaxy s2 error message charging paused voltage too high
Dear Please try it:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 02, 2012 | Cell Phones
How to splice samsung galaxy s cell phone car charger to wall charger
you should just do white to white and ref to red. just so you should know that ac chargers have a special crossover that the phone knows it is charging not usb' ing to a computer so you may get message on the phone to go into usb mode...just hot home and you well be fine
Apr 02, 2012 | Samsung Galaxy S 4G Cell Phone
Cannot charge Samsung Galaxy S2
first, test th charger with another phone to confirm if its working or not.
If the rempte is working, then it means the charging port of your phone is defective and needs to be replaced.
Regards.
Jan 05, 2012 | Cell Phones
MY SAMSUNG GALAXY S2 WONT CHARGE
Try connecting your S2 with the usb cable provided to your desktop/laptop. If it starts recharging, then it is definitely your charger thats done for. Get a new charger...
Oct 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cell Phones Logo
1,062 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
