Question about Compaq Evo N1020V Notebook
My compaq evo n1020v freezes,on restarting blank screen fan on
Usually occurs on moving laptop whilst on.On switching off and restarting blank screen but fan on or freezes when booting
  • Jay
    Jay May 11, 2010
    Can you rephrase your problem it a bit confusing.
How to connect external monitor compaq evo n1020v
Plug the cable VGA in to the compac and the laptop. than go to graphic properties and activate your extended desktop. You can also use the monitor as a second one, or clone
Jan 29, 2013 | Compaq Evo N1020V PC Notebook
I have a Compaq N1020v with a 14.1 display. The LCD was cracked and I plan to replace it. I would like to replace it with the 15 inch display for the Compaq N1020v. Will that work, or is the 15.0 to big?
It depends on how "adaptable" the mounts on the "surround" of the LCD screen, i.e., whether the one "surround" was used by COMPAQ for both 14" and 15" LCD screens, or whether the part-numbers were different.
Aug 09, 2010 | Compaq Evo N1020V PC Notebook
Power hub usb problem . compaq laptop evo n1020v. do i need to update the bios?
Please uninstall all the USB Drivers from the Device Manager and then restart the Computer. The USB Drivers are Operating System generic Drivers. The Computer will reinstall the Drivers for USB automatically
Jun 30, 2010 | Compaq Evo N1020V Notebook
First conclusion: This is not a software fixable problem. If your notebook is still in warranty, I suggest you to RMA it. No doubt somethings broken.
Jan 23, 2009 | Compaq Evo N1020V Notebook
MY LAPTOP COMPAQ N1020 V HAS A BOOTING PROBLEM
I'm not sure what good getting into safe mode is going to do?
More than likely this is a hardware problem - If you have already tried different RAM the next thing would be CPU. You may be able to just reseat the CPU in it's socket to help things out.
On the N1020v to access the CPU, you just have to remove 2 screws underneath the power button strip and then the keyboard just pops up. Remove the heatsink and the CPU is right there. If you want to replace it use the part number on the CPU itself (something like SL245)
To forewarn you though - i have worked on these laptops many times and more often the problem is a failing motherboard than a bad CPU or RAM. However it is worth a shot at fixing it if it just needs a CPU.
Don
Dec 18, 2007 | Compaq Evo N1020V Notebook
System Freeze after WLI-CB-G54s is inserted
Restart your Compaq Evo N1020v laptop without the card inserted. Go into the BIOS (by hitting F10), change the UMA Frame Buffer Size from 32MB to 64MB (located in the Advanced menu), reboot and install the card drivers and insert thecard. This should fix the problem.
Nov 02, 2007 | Buffalo Technology AirStation WLI-CB-G54S...
Dead screen
restoring the BIOS settings to the default should solve your problem.
Oct 03, 2007 | Compaq Evo N1020V Notebook
Computers & Internet Logo
363 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
