Question about Panasonic Workio DP-2500E Copier
Panasonic dp-2500 hi, ren16, thanks for your reply. the main problem i am having is in my country, panasonic dealer does not provide services for this model. so i somehow managed to find a technicion from that company and did a service. i was present when the guy did the service. i think near the drum he showed me a roller ( i think this is called magroller) and said he is unable to clean tat because the black pouder sorrounding one was a magnetic one, and he said we cant by that in my country. but according to you, normall toner is in magroller. please let me know is it safe to remove what ever surrounding in this roller. (mag roller pic http://www.alibaba.com/showroom/Mag_Roller.html) please let me know only thing surrounding the magnetic roller is also normal toner, if not do i need to buy something else. because when touch that roller te ouder was moving due to magnetic effect. thanks oo7
  • eupu Jan 26, 2009
    first of all thank you for your kind reply.
    there is no lines on the copy or the printout. its just the density of black is less. for example if I print a black and white image, i want see black areas as fully black, instead there are white spaces which not been printed properly. furthermore, when i touch the printouts black does not come out.
    from your repond i understand there is no special powder for mag roller, its just normall toner.
    again thanks
    oo7
  • Panasonic Expert
  • 1,326 Answers
Are you getting black lines or white lines on your copies? If you have a problem wit void or white lines it may be in the developing unit. You can use a dry rag to wipe off the mag. roller, but I think your problem is with the drum unit & the primary charge roller. In that copier the drum is on the developing unit. I think your tech is miss leading you or trying to charge you for a very coastly part. You can get a new drum for $20.00 or so...Good Luck
Posted on Jan 25, 2009
Looking for panasonic model vsk0317where can I aquire?
The VSK-0317 Digital Camera Charger is available for purchase at the Panasonic Authorized Dealers and Service centers. Click here to contact the Panasonic Dealers and Service centers near your area. Select the Country or Area and then the the Dealers or Service Center sublinks.
Good Luck!
Thanks for using FixYa
Dec 01, 2010 | Panasonic Cameras
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
May 13, 2010 | Panasonic Workio DP-2000P Copier
Compatible for network card and fax kit
Due to the age of the copier the fax card and Network board may no longer be available.You will need to contact a Panasonic Copier Dealer in your country.This will need to be fitted by a Qualified Technician.
Nov 18, 2009 | Panasonic Workio DP-2500E Copier
Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Sep 23, 2008 | Panasonic Workio DP-2500E Copier
Service Manual Download -> Exchange Drum of DP-2500
For the service manual of a Panasonic DP-2500, pls try here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Panasonic Workio DP-2500E Copier
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Mar 31, 2008 | Panasonic Workio DP-2500E Copier
NO ENGLISH IN THE LIST OF LANGUAGES
possibly your machine is imported from other region countries. it can only be solved by performing firmware update offcourse using an english language firmware. But only a panasonic service provider can do that because the firmwares are beeing keep by panasonic.
Mar 28, 2008 | Panasonic Workio DP-2500E Copier
Servicing
Hi B.
My geographic knowledge of Oz is not great.
So click this link it will give you the main panasonic dealers in Oz.
If one of them is close they will asssist, or thye will put you in touch with a closer dealer.
Let me know if this is useful.
Jan 11, 2008 | Panasonic DP-1810P Laser Printer
Panasonic Workio DP-2500E Copier Logo
239 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
