Question about ASUS U52F-BBL9 Laptop
I have a ASUS U52F Laptop I cannot load Windows 7. I am in ASUS Preload Wizard, I have 3 options to choose from 1) Recover Windows to First Partition Only. 2) Recover Windows to Entire HD. & 3) Recover Windows to Entire HD with Two Partitions. Which one should I use, and will any of the 3 help me retain my data, pictures, ect... Any help will be very appreciated. Thank for your help.
  • Craig Wright Jan 14, 2013
    I am not trying to add windows 7, it's my OS and it will not load at startup.
    Problem Solver:
  • 6 Answers
You should remove your HDD Hardisk Drive and slave to other PC so that you can Backup your files Picture, Music Ect.
After backup all your files you may now proceed recovering your windows each either 1 or 2 option must be follow.
Best selection is Option 2 Recover Windows to Entire HD
Posted on Jan 14, 2013
3 Suggested Answers
  • 165 Answers
SOURCE: I have an Asus G1
Have you tried a hard booting of computer?
Posted on Mar 23, 2009
  • 41 Answers
SOURCE: When i open my laptop,
first, recover your files. You will need to use something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Posted on Oct 28, 2012
Factory Restore
Try F9 during boot.. I doubt you repartitioned that small partition when you reformatted the main partition of the drive. Then again, the F9 function might not work anymore, even though the partition is still intact.. From Asus Support:
Using the Recovery Partition(on selected models)
1. Press < F9 > during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click Next.
4. Read the ASUS Preload Wizard messages and click Next.
5. Select a partition option and click Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates a new system partition as drive "C".
Recover Windows to entire HD with two partitions.
This option deletes all partitions from your hard drive and creates two new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery process.
Dec 12, 2013 | ASUS K52F Notebook
Asus k53 Windows 7 image
Since there are several windows versions available for this laptop, you can download the correct drivers from here: http://support.asus.com/download/options.aspx?SLanguage=en&type=1
Jul 28, 2013 | ASUS K53SV Notebook
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
Next.
Next.
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
Asus u52f disk read error on recover disk
Run the Check Disk Utility if the operating system is loaded.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 28, 2012 | ASUS U52F-BBL9 Laptop
Hi, is there any way i can recieve a free cd or direct download of a recovery/reboot disc for my Asus G50v (Windows Vista Home Premium) laptop? i want to have it back to factory settings like when i first...
Hello.. It is Very Possible that you have what is called a 'RECOVERY PARTITION', which has the rerecovery disk information installed on your Hard Drive. This eliminates having to use a CD. To access the Recovery Partition do the following: 1) Press F9 during Bootup. 2) Press [Enter] to Select Windows Setup [EMS Enabled] 3) Read the 'ASUS Preload Wizard' screen and click NEXT. 4) Select Partition Option and click NEXT. 5) FOLLOW INSTRUCTIONS TO COMPLETE RECOVERY PROCESS. ***Visit www.asus.com for updated Drivers and Utilities***
GREAT LUCK TO YOU!!!
Aug 09, 2011 | ASUS G50V-A1 Notebook
Hey i have an asus U52F laptop. i wish to restore it to factory settings, and wipe everything from its memory. i dont have a windows seven cd, and dont know how to restore it. if you could help that would...
start by getting the user manual http://support.asus.com/download/download.aspx?SLanguage=en-us
have it available on another computer or print out what you think you may need
at start-up press f-9 to enter setup
press enter to select windows setup
select language than press next
read the asus preload wizard messages click next
select partition options click next
follow the onscreen instructions to complete the recovery process
visit the above website to get updated drivers for your laptop
Dec 07, 2010 | ASUS U52F-BBL9 Laptop
My laptop which is now 3 yrs old is CONSTANTLY rebooting. It acts as if it is going to fully load Windows XP, but then starts the reboot phase all over again. Is there anything I can do to stop this? I am...
Hi Good day!! try to run your windows in Safemode, to run in safemode, press f8 continuously while booting your pc. Option will appear after pressing f8 choose safemode. your pc will start in safemode. after that do some scanning and then reboot your pc see if your windows will start normally. if not work please relpy to me and i will assist you more thanks!!!
Don't forget to vote Thanks!!!
Oct 28, 2010 | Computers & Internet
Need to reset to factory defaults
Restart your computer. Press F9 key immediately when the ASUS logo appears. This will start the recovery procedure, including the installation of all the drivers and utilities. Follow the instructions. Your computer will be restored to the factory settings.
1. Recover windows to first partition only. this option will delete only the first partition, allowing you to keep other partitions, and create a new system partition as drive "c". 2. Recover windows to entire HD. This option will delete all partitions from your hard disk drive and create a new system partition as drive "C". 3. Recover windows to entire HD with 2 partition. This option will delete all partitions from your hard drive and create two new partitions "C" (60%) and "D" (40%).
Usually, the brand new ASUS notebook computer hard disk is with 2 partitions. So, it is suggested that you select “3. Recover windows to entire HD with 2 partitions”.
Thanks for using Fixya
Jul 28, 2010 | ASUS Computers & Internet
How doI reset my Toshiba Laptop with Vista 64 bit to factory settings?
There are two ways to reset your Toshiba Laptop to factory settings.
First is using Recovery Media Disc and the second is the hidden partition on your hard drive.
If you're going to use Recovery Media Disc follow these steps:
If you have two or more recovery media disc try to insert first the disc that has a label of 1 of 2 or 1 of 3. Then turn of your laptop.
Make sure that the disc is inside. After that try to find the letter "C" key on your keyboard. Now turn on your laptop and keep tapping the letter "C" key. If you have successfully accessed the Boot Menu choose Toshiba Recovery Wizard.
After choosing the Toshiba Recovery Wizard there will be a big warning screen that will appear choose the option yes and after that you will have a series of option. Remember to choose always the first option after the big warning screen appears.
That's it. You will have a message that the Windows is initializing files.
That process will take 1-2 hours for it to finish.
Hidden Partition on the Hard Drive.
Turn on the laptop and as soon as the laptop turns on press and hold down the number 0 key (the number 0 it should be on the top of the keyboard beside the number 9 key) keep 0 pressed until Toshiba leading innovation appears. Usually you will have a beeping sound when you are trying to access the System Recovery of the Hard Drive. That's an indication that you have successfully accessed the Systrem Recovery of the laptop.
Wait for the screen that say Windows is loading files.
After that you will see a big warning screen the choose yes and
Choose 1st option always.
Cx able to initialize the partition.
Disconnect cables and turn off the wireless switch.
Recovery would take 1-2 hours for it to finish.
Nov 13, 2009 | Toshiba Satellite L305D-S5904 Laptop
ASUS U52F-BBL9 Laptop Logo
94 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
