Question about Delta Home
Parts for 80's deltex delta shower stems
  • 659 Answers
SOURCE: low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Posted on Apr 05, 2009
  • 659 Answers
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Posted on Apr 10, 2009
  • 129 Answers
SOURCE: moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Posted on Sep 29, 2009
  • 186 Answers
SOURCE: I need replacement parts
Hello. I looked at the Delta website and you product seems to have a lifetime warranty.The link below will take you to the waranty page and has contact information.
builderdale
http://www.deltafaucet.com/customersupport/warranty.html
Posted on Mar 02, 2010
  • 14331 Answers
SOURCE: i installed this delta shower set & water
remove handle and adjust the cold and hot clips one is set to open to much if u still have the paperwork in it will show how to adjust it also
Posted on May 06, 2010
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
Leaks
replace rubber seat cups and springs. replace stem and ball with brass parts if available.they last longer than the nylon ones. lubricate moving parts with valve stem grease. do not over tighten when re-assembling
Sep 16, 2010 | Delta Faucet Home
Looking for the stem unit diagram from delta for their single handle shower unit that uses the stem rp1991. in the info leaflet that comes with the replacement they refer to a spring. I want a diagram to...
You can go to the link below to get a parts breakdown of your style of Delta. The seats and springs are recessed into the valve body behind the RP1991 stem. The flat part of the stem rotates back and forth across surface of the rubber seat, so in time the rubber surface wears flat and the spring can no longer push it firmly against the stem.and then the faucet drips.
http://www.plumbingpartsdepot.com/delta1600.pdf
Aug 04, 2010 | Home
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Delta single handle faucet leaks
BEHIND THE HANDLE THERE SHOULD BE A SET SCREW THAT HOLDS THE HANDLE ON THE STEM. THE SET SCREW WILL BE BEHIND THE LONGEST PART OF THE HANDLE LOOK AROUND BACK OF THE HANDLE. AFTER REMOVING THE HANDLA THERE WILL BE A STEM AND A NUT THAT HOLDS THE ASSEMBLY IN THE HOUSING
Sep 16, 2009 | Delta & Single Handle Shower Faucet
Low flow hot water in Delta Shower
Apr 05, 2009 | Delta & Single Handle Shower Faucet
Home Logo
253 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
