Question about Sewing Machines
The race is damaged - Sewing Machines
  • Sewing Machines Master
  • 7,365 Answers
Then the race needs to be replaced at a sewing machine shop
and also make sure they check the timing
Posted on Jan 14, 2013
Th race will not stay in place
it's possible that the race may be damaged & needs to be replaced
Mar 14, 2012 | Singer 3116 Simple
Bernina 130. The upper needle is working but it does not seem to be abLe to catch the bottom thread. Had this machine for 12 years so I know how to put the bobbin in. Any ideas?
Firstly, I assume you've cleaned-out under the stitch-plate and after removing the bobbin, have removed the hook/shuttle, cleaned the hook race and given the hook race a drop of oil. Whilst you've got the hook/shuttle out, just check that the point is not damaged. Also, if you've got the lightweight hook/shuttle often fitted to these machines (it's black plastic with a metal outer/point), make sure there's no needle damage to the plastic - sometimes this can catch the thread as the hook rotates, preventing the loop from being picked-up. After doing that, check if you can sew straight stitch with the needle in centre, fully left and fully right. If it works in one location but not the others, there could be a number of issues such as timing/synchronisation or possibly the needle bar is offset front-to-back so that there's too large a spacing between the needle and hook.
Nov 13, 2011 | Bernina Activa 130
Brother pc-420 bobbin case shifts and jams everything up and I've went through 20 needles where they keep breaking off...can anyone tell me why the bobbin case is rotating completely out of...
it's possible that the bobbin case is damaged, it's also possible that the hook or hook race could be damaged,,it's also possible that the hook & hook race are
out of time. only a sewing machine repair shop can say for sure
Oct 13, 2011 | Brother PC-420
Elna Supermatic G62 problem with bobbin race. If I rotate the handwheel, the shaft that drives the bobbin race rotates faltering. If I hold left index finger lightly against the bobbin holder, the race...
Bit technical for me but I'd suggest you join the Elna Heirlooms group on Yahoo.com, and then ask there, there are lots of very helpful members who share photos, service manuals and their vast knowlege on these vintage machines.
Feb 09, 2011 | Elna Sewing Machines
My machine keeps jamming, what happens is that the top thread gets caught in the hook how do i solve this
Be sure there are no thread tails hanging from the bobbin when it's inserted into the bobbin case. They can jam the machine and cause the upper thread to break. And note that there's no such thing as a generic bobbin. Always use a bobbin designed for your machine in order to avoid skipped stitches, loose threads, and noise, as well as permanent damage to the bobbin case.
Clean your bobbin case and open the race (what you insert the bobbin into) to clean that out as well as the feed dogs. Excess lint can cause a lot of trouble when you're sewing so cleaning and oiling often can save you frustration and damage. Also use a quality thread that will not add to the lint build up.
Your race might also have a small burr that needs to be gently rubbed off. Do not use sandpaper as that will cause more burrs to form.
Hope this helped.
Jan 20, 2011 | Singer Sewing Machines
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
I am attempting to check to see .. if the RACE for my Brother XL-6562 has sustained some damage (the smaller point broken, perhaps) -?- Long story short: the needle had fallen down into the machine; I...
Be sure you didn't put the bobbin in the bobbincase upside down.
I hope you mean the plastic hook that sits in the metal race is damaged because they are cheap and easy to replace. Also if the tip is damaged at all, even a nick or a burr the thread will catch on it. If its a plastic one replace it with a new one from where you bought the machine or check with a real sewing machine dealer or repair person. Unless you can smooth it out by polishing it or using a very fine emery paper (for a metal one) it needs a new one. The thread will only keep catching on it. The hook is inexpensive. The race that the hook sits in is probably metal is an inexpensive part but an expensive fix.
Good luck.
Jan 10, 2009 | Brother XL-6562 Mechanical Sewing Machine
Janome 9000 Needle Keeps Breaking!
I think you may have to use some sort of tear away paper on top of the loops so the needle doesn't get caught, as well as stabiliser underneath. I just checked the manual for my janome and that's what it says for towelling.
Nov 28, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
