Question about LG Washing Machines
I have a10Kg top loading washing machine - Model WT-R107 purchased in August 2012. When I set the machine on a Perm Press wash the cycle commenced normally then it suddenly stopped and indicated an IE error message. I checked the water supply and all was ok. So I switched off the machine and just ran it on the speed wash cycle and it worked ok. Why did the machine stop and indicate an IE message when on the Perm Press cycle?
  • LG Master
  • 2,308 Answers
One of the inlet water valves is not working
Posted on Jul 13, 2017
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
SOURCE: GE washing machine water overflowing
sound like the same washing machine from hell that we have. three or four times it has overflowed from want we have been told the hose that runs from the drum to on/off pressure switch cloggeds with soap. we have tried different soap,hot water,cold,water you name it we've tried it. so now evey time we use it we have to clean it with a coat hanger by taking the front off the machine.
P.S. take the hose off top and bottom to clean it, all it takes two/three very small soap bubbles to clogged it
Posted on Dec 30, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
• Water supply is not adequate in
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
Posted on Aug 02, 2009
I replaced the drain pump but machine is making a noise like its goin through spin cycle when turned on. Water drains right out aswell HELP
if the pump is working all the time then it will be the program board
make sure that after you replaced the pump the drain hose outlet was higher than the tub or all the water will run out
Feb 23, 2016 | Washing Machines
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Washing machine getting hung on a cycle
If the machine is 14 years old, it probably is time to replace it.
Jun 06, 2017 | KitchenAid KAWS850L Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Users manual
The LG Canada website has it.
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
Will not wash!!
I would recommend starting off by trying a different cycle. Change the dial to the spin cylce, or a different type (perm press, normal, knits) and see if it has the same problem.
May 09, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
